Does the Act clutch kit Need/Bring a retaining clip?
Old Oct 29, 2012 | 06:41 PM
Randal's Avatar
Guest
I noticed by Act clutch when I removed it had a retaining clip with a wavy spring. Do the Act clutc kits bring/need it? I tried searching for an Act one but they only make an exedy wave lock retaining clip.
This is what I am talking about. All this came out of the pressure plate when I removed it. Is this something i need to buy or does the Act clutch kit bring all this?
Attached Thumbnails Does the Act clutch kit Need/Bring a retaining clip?-image.jpg
Old Oct 29, 2012 | 07:38 PM
lostsoulsevo's Avatar
the act clutch comes with a new wave ring clilp
Old Oct 29, 2012 | 07:39 PM
Randal's Avatar
Guest
How about the rest of the hardware shown that was attached to the pressure plate splines?
Old Oct 29, 2012 | 09:55 PM
yes everything pictured comes with the clutch kit
Old Oct 30, 2012 | 04:20 AM
Randal's Avatar
Guest
Also the 3 flywheel metal dowels were cut off when resurfaced because the machine shop could not remove them. No problem ?
Old Oct 30, 2012 | 05:22 AM
the dowels are used to line up the pressure plate with the flywheel, if you can line it up properly i would guess it would be alright. but i personally wouldnt use it, i would buy a new flywheel
Old Oct 30, 2012 | 06:02 AM
Randal's Avatar
Guest
I can't afford right now to buy a flywheel. The guide pins are just to guide the clutch in. From what the machine shop told me its useless beyond that.
Old Oct 30, 2012 | 09:13 AM
that is true, but if your clutch doesnt sit flush on the flywheel goodluck getting the tranny back on
Old Oct 30, 2012 | 09:34 AM
Randal's Avatar
Guest
Yeah I will have to align it just the way it would of been with the pins. Then insert the 6 bolts and torque them.
Old Oct 30, 2012 | 06:38 PM
ACTman's Avatar
The dowel pins are important to keep the pressure plate centered on the flywheel and maintain proper balance of the spinning assembly. Running without them would risk unnecessary vibration and/or engine bearing damage from the out-of-balance condition.
Old Oct 30, 2012 | 07:03 PM
Dirk Starksen
President
Advanced Clutch Technology Inc.
EDIT: PM Sent
Old Oct 30, 2012 | 08:20 PM
Randal's Avatar
Guest
I don't see how it will be off balance. There are three dowel pins equally placed like a pyramid. If you cut them off it will still be in balance. The pressure plate is not going anywhere, with the six bolts that's bolted together.
Just to say some of your flywheels don't even come with dowels.
Old Oct 30, 2012 | 09:01 PM
ACT flywheels do come with dowels, i have the streetlite act flywheel and it had dowels
Old Oct 30, 2012 | 09:25 PM
Randal's Avatar
Guest
I don't see how the pressure plate can't align itself once you bolt on the 6 bolts. Is the clearance from the dowel to the pressure plate tighter then the clearance of the bolt and the pressure plate opening for the bolt to go thru?
Old Oct 30, 2012 | 10:13 PM
the holes from the pressure plate to the dowels on the flywheel are a very tight fit to ensure vibrations dont allow the bolts to come loose. but its your car, we have given you our advice and we all said dont do it and buy a new flywheel. up to you now.
