oil leak issue
oil leak issue
I need some help on this oil leak issue im having on my evo 8. i see verry slowly drips of oil on the oil cooler line" only the line thats right on top of the crank pulley. i also see oil right under the crank plastic cover on the outside. i will post pictures soon. my question is what could be the couse other than front main seal? i was told i might have a balance shaft eliminator kit since my car has some vibations at idle and at speeds.
seal behind oil pump pulley possibly but it could be crank seal or as you mentioned the blanking plug ive also seen them leak through the hyd tensioner bolts threads a little bit of sealer on the threads will cure it.
TonyG
40
Nov 23, 2016 01:27 PM
NOMIEZVR4
Aug 31, 2013 12:54 PM
waits6561
Jan 20, 2013 12:22 PM
