Does the Evo 8 use two O2 sensors?
Old Nov 4, 2012 | 03:13 PM
Randal's Avatar
Guest
So I replaced my clutch and noticed that the O2 sensor in front of the straight pipe does not have a socket nearby to plug into!?!? But the rear one does. Now all of a sudden my air/fuel ratio gauge is not but working. Do they use one or two o2s? My evo is tuned.
Old Nov 4, 2012 | 03:16 PM
EvoLutionized8's Avatar
you have a front O2 sensor that plugs directly into your O2 housing coming off your hotside of the turbine housing. You must plug it in or itll run like junk, as you're experiencing.
Old Nov 4, 2012 | 04:02 PM
Randal's Avatar
Guest
I have an aftermarket tomei o2 housing with an o2 sensor. All my 400whp are running perfect with no hiccups. I only have 3 02 sensors but only two are connected . My only problem is my air/fuel gauge is on but not working. I don't know where the connection is.
Old Nov 4, 2012 | 04:09 PM
CurseDSM's Avatar
I have all 3 in mine with no issues.
Old Nov 4, 2012 | 04:14 PM
Randal's Avatar
Guest
I have three but only two are used.
Old Nov 4, 2012 | 04:15 PM
Randal's Avatar
Guest
To which o2 sensor does the air/fuel ratio connect to? Or where does it wire up to?
Old Nov 4, 2012 | 04:19 PM
EvilTechnology's Avatar
Since it's an aftermarket gauge and hence an aftermarket sensor, there is no clear universal answer. You could ask the shop that installed it the first time or just spend some quality time under your car and find the bung for it.
3bar_dc2
Feb 24, 2016 12:51 PM
Seancj
Jul 14, 2015 02:45 PM
evilevo22
Oct 3, 2007 02:36 PM
EvO6-RS2
21
Sep 1, 2006 12:42 PM
Option2
May 24, 2006 08:20 PM
