evo 8 evo 9 turbo swap questions
hey so just wondering Ive read that you need to buy evo 9 lines for an evo 9 swap on an evo 8 turbo before I get the turbo I want to make sure I know what I need to get Im pretty sure I know but I saw my friends evo 9 turbo I was looking at buying and it looks like all the oil and water lines are the same?
Other then the oil return life is there anything that I need for a evo 9 swap?
Yeah you will definitely need a J pipe and yes if you are switching from a 9.8 now to a evo 9 10.5 hotside then it does make a difference. Also if you are on e85 then yes it still does make a difference between evo 8 and 9 in my opinion. Depends what mods you have and what you consider to be a difference too. You can always port the turbo too for a little better flow and power as well. If you get an evo 9 for cheap with the lines and j pipe then in my opinion its worth it.
This link help me alot and might help you answer question.
http://www.boostedfilms.com/joomla/e...-9-differences
This Ebay kit has everything you need and it's cheap $45! (you don't wanna reuse copper washers, gaskets, and all those misc items)
http://www.ebay.com/itm/Turbo-Oil-Wa...7ab6cf&vxp=mtr
Here's my experience going from 8 to 9 turbo:
https://www.evolutionm.net/forums/8880853-post47.html
My opinion is that for autocrossing and street purposes, the evo9 turbo with E85 is a killer setup--very minimal lag and lots of potential (~400awhp near its max). On 93oct, however, I wanted more power and ultimately went with a BBK Full on E85.
Evo 9 water and oil lines work on the 8 motor, but you have to have the 9 j-pipe (compressor outlet piece) too, the 8 one on the 9 turbo will hit the starter. If the 9 turbo you get comes with the lines and the j-pipe, you don't need the install kit.
read this thread and you determine if you're comfortable bending lines and such:
https://www.evolutionm.net/forums/ev...s-9-turbo.html
