550+ Build Opinions, need help...
Motor has started making noise. Pretty sure its a rod bearing. Im looking to build the 2.0 with an EF3 on e85. Wanting to hit somewhere between 550-600. Need some opinions on rods, pistons and crank if needed?, will also be doing headstuds. And anything else I should do while I'm in there. This is a steet/weekend car, so dont need anything too crazy. Clutch has been upgraded and going to do a shep trans soon. Just looking for engine help. Thanks
2.0 is always good for about 1,000 rpm over a 2.3. Its all dependant on parts though. I would go with a forged manley crank if the budget allows, its well under $600 street price. I would also go with some sort of i beam rod. Lots of good pistons. Buschur, wiseco h.d., arias, etc.
If its a fully built block, cams springs retainers, a 2.3 is safely to 8k, no reason to push it over that. Without the head built up though its kinda pointless.
Built 2.0, 2.2 or 2.4 engines have seen 8-10k rpms depending on supporting mods. Again, on a street car you dont need to go that high
8k is fine, idk the pros and cons of 2.0 vs 2.3, if its better to go 2.3L i can afford a new crank... How about the OEM 100mm crank? is it better to get something like a Manley forged crank?
I'm amazed at the near universal appeal of the stroker motors. From a longevity standpoint, I could never get past the reduced rod/stroke ratio and thinner cylinder walls on the 4G64 block.
not so sure about this being true and if they are smaller i would guess it's by 1.5mm which is about .030" per side which is extremely small.i have actually heard that they are thicker from a few people though.
Best of everything, displacement, revvs.
