leak tested - blows from valve cover
Old Nov 11, 2012 | 03:25 AM
stunt2's Avatar
Question leak tested - blows from valve cover
as above, air is blowing out from breather hose that is on the righ side of valve cover and goes to intake pipe
is it normal ? is the valve cover pressurized when performing leak test ?
Old Nov 11, 2012 | 03:51 AM
griceiv's Avatar
normal.
Old Nov 11, 2012 | 06:21 AM
cfdfireman1's Avatar
depends how much it's blowing. could indicate bad rings or PCV.
Old Nov 11, 2012 | 06:35 AM
stunt2's Avatar
don't know how to discribe if it's blowing much or not because I dont know how much is normal...
if the rings are faulty compression test should reveal that, right ?
Old Nov 11, 2012 | 08:14 AM
mrfred's Avatar
I always get some but hard to quantify.
Old Nov 11, 2012 | 08:24 AM
stunt2's Avatar
tested another car too, that had no such issue at all
interesting on what does it depend
Old Nov 11, 2012 | 10:02 AM
fireroasted's Avatar
I had the same, but still 90s, or green, depending on which tester I used. What did the test indicate while it was whistling out of there? If you had significant and appropriate psi in the compressor, some leak is normal.
The gauge should tell you if its out of spec or something to worry about. It may be obvious, but make sure to wiggle back and forth the crank (therefore cam) position to get the best seal.
Old Nov 11, 2012 | 10:47 AM
stunt2's Avatar
I hit 24-25 psi at the gauge. haven't tested any further
Old Nov 11, 2012 | 04:37 PM
I didn't follow that. My leak down tester requires air pressure of 80 psi constant and will then indicate what percentage of leak. Something like 90 is green and all good. 80 is orange and its OK, but engine age showing. Some carbon build up maybe. The 70 and 60 down into the red, and there you have a problem.
Old Nov 11, 2012 | 04:53 PM
Trigger390's Avatar
believe the OP is doing a boost leak test, not a cylinder leakdown test.
OP, did you have the engine at TDC when doing the test? My car will leak bad out of the valve cover if its not at TDC. Just a thought.
Old Nov 11, 2012 | 05:02 PM
Yup, my bad, I read leak and test and my mind went to leak down. When I do a boost leak mine will blow out of the valve cover pretty good.
Old Nov 11, 2012 | 10:03 PM
stunt2's Avatar
Trigger390
no mate, just turned off the engine and performed the test
so as I've read posts above, there's nothing to worry about
Old Nov 11, 2012 | 10:33 PM
chad99evo's Avatar
the pcv likes to leak. unplug the hose and shut it off with a rubber plug and zip tie. see if it keeps leaking. can narrow down search.
if full leak test it can sometimes be a PITA to get it dead on TDC
Old Nov 11, 2012 | 10:49 PM
chad99evo's Avatar
did i read something wrong, omg you're putting 80 psi in there??? for boost leak??
Old Nov 12, 2012 | 12:38 AM
stunt2's Avatar
no, in the combustion chamber
he was talking about leak down test
