did compression test...need opinions please
cyl (1) 180 (2) 170 (3) 170 (4) 165
wet test cyl (1) 180 (2) 180 (3) 180 (4) 180
i'm thinking my block is good, but head studs need to be retorqued due to cyl 4 reading low? would appreciate peoples input! thanks
motor is stock, no aftermarket parts at all. did the compression test to start modding. but i think i have set backs....what do you all think?
My advice would be a leakdown to pinpoint where you're getting the compression loss... can you explain you wet test process? If it's just oil in the cylinder and the results evened out, I'd say that the oil on the cylinder wall improved compression and your rings are slightly worn for those cylinders. What makes you think gasses are leaking across the head surface (you mentioned tightening headstuds)?
my reasoning for retorquing the head studs are because cyl 2,3 are on the same stroke and if the compression reading was low and the same it could be caused by the headgasket. in this case the reading is good and the same, cyl 1,4 are 15psi off. dont get me wrong i understand when doing a wet test and compression rises it could mean faulty rings. i put oil in the cylinders for my wet test.
stock motor has 75k miles, i'm glad i'm doing this now....will save me money down the road when i plan to build this thing.
I don't think you have anything to worry about. If there were headgasket issues, it would be more apparent than through a cranking compression test. Think of how high pressure ratio is during a firing event.
thanks
i might redo the compression test, i cranked each cylinder for 5sec....i've been reading around here and people were cranking longer. or run the car longer to charge battery and redo cyl 4. i need to make sure this motor is good, i plan on going with a STM 6266 kit with all supporting mods
