Infamous low idle issue
Old Nov 23, 2012 | 06:41 PM
04AWDTURBOEVO's Avatar
Originally Posted by Jprice
Thats the IAC valve, I just replaced that and it did not help. Starting to think now it could be the BOV (it is recirculated)
If you replaced the idle speed control motor, did you check for the correct position?
You must check the voltage on the part before fastening bolts.
It has to be within specified range.
Double check this.
Old Nov 23, 2012 | 07:48 PM
Clessy's Avatar
Veteran: Army
Im in the same boat as this guy except my cars gotten to the point where it does die out. So any time im about to come to a stop I have to hold my clutch in and rev so the car doesnt die out. Even starting the car is a hassle without excessive reving because the idle starts so low.
I've got 3 engine codes so ima start working with them. Obviously starting from the cheapest and going forward.
When the codes are pulled on all 3 it mentioned a vaccum leak could be the source of them all so i'd like know how to go about this or if its even worth my time. Should I just take it somewhere and have them fight the demons.
Old Nov 24, 2012 | 02:45 PM
Jprice's Avatar
Originally Posted by Boosted Tuning
You should make sure your BISS is set up correctly, by using evoscan. It should/may help.
ah, i need to buy evoscan. Can the dealer do some sort of scan on it?
Old Nov 26, 2012 | 07:02 AM
scheides's Avatar
EvoM Moderator
Fujita intake is a hard pipe, I would swap in a Perrin or samco.
Old Nov 26, 2012 | 01:37 PM
Jprice's Avatar
so i took the car to the dealer today and they did a ecu update which made it run a little better but its def still not right. they said when they disabled the maf it ran great so should i try that speed density conversion??
http://www.awdmotorsports.com/produc...eeddensity.htm
will i need a tune for this or do i just plug up and go?
Old Nov 26, 2012 | 06:16 PM
scheides's Avatar
EvoM Moderator
You're doing it wrong. First off, dealer flash will get you nowhere, absolutely nowhere. You need to get the ecu tuned by a professional tuner to help cure the idle issues. Basically you need to add timing to the idle area of the timing map.
This is only the first step...as I have said multiple times, the hard pipe intake you have is probably causing a lot of your issues.
Finally, 110% no you cannot just plug in a SD kit 'and go'. Read through this how-to for a general overview but see recommendation #1 above and find a professional tuner to work with!
https://www.evolutionm.net/forums/ec...ched-roms.html
Good luck!
Old Nov 26, 2012 | 06:22 PM
Jprice's Avatar
thanks for the info man
Old Nov 27, 2012 | 11:10 AM
MrJuls's Avatar
Mine also does this but only when the car is cold.So I always have to let it idle a bit before I go otherwise It will just die...
VtexGt3
Sep 8, 2014 02:48 PM
supersal
Apr 14, 2012 07:18 AM
Jamesm331
Feb 29, 2012 08:32 AM
MitsuJDM
11
Sep 4, 2011 04:36 PM
