IX turbo question
Old Nov 27, 2012 | 12:40 AM
stunt2's Avatar
Question IX turbo question
I'm interested if VIII 10.5 and IX hotsides are the same, (to bolt 8 hotside to the 9 turbo)
and
if the IX oil/water lines are same as VIII. if not, which lines do I need to bolt up 9 turbo on evo 8. original VIII ones or the lines that will come with IX turbo ?
thanks
Old Nov 27, 2012 | 07:37 AM
kaonashi's Avatar
and
thanks
Most of this can be found on here already, they are not 100% the same the evo 8 10.5 has a double flapper & the 9 I purchased from a dealer had a bigger single flapper but they should bolt up just fine. One of the lines is different i want to say it was the oil lines but I could be wrong haven't taken one off in awhile. I would buy a IX install kit anyways because the J pipe will be different.
Old Nov 27, 2012 | 09:41 AM
stunt2's Avatar
thanks for answer
8's had single flapper hoisings as well. I personally have the one
Old Nov 27, 2012 | 12:10 PM
kaonashi's Avatar
thanks for answer
Not sure on that the 03 and this 05 are both double flappers. the only single I've seen was my FPgreen and the stock IX.
DisgustipatedM3
Mar 1, 2013 02:50 PM
GSX 911
Sep 16, 2012 10:03 AM
TwistedEvo8
Dec 26, 2011 12:03 PM
tim85851
Apr 2, 2011 02:01 PM
jmelocik
26
Apr 27, 2010 11:50 AM
