Are Evo 8 & Evo IX Crankshafts the same?
Old Sep 14, 2012 | 09:02 PM
GSX 911's Avatar
Hey I cant bolt up my flywheel to my crank due to the crank only being able to 6 out of 7 flywheel bolts.
I found a couple on Ebay but they list them as 03-05 Evo VIII/8. Will the Evo 8 crank fit on an Evo IX/9? Are they the same exact OEM piece. I have an Evo IX
Old Sep 14, 2012 | 10:34 PM
adriano_917's Avatar
According to AWD motorsports they should be the same for the 8 and 9. Thread just a tad of each bolt ad see if you can get them all in.
http://www.awdmotorsports.com/product_p/md357543.htm
Old Sep 14, 2012 | 11:20 PM
deylag's Avatar
Is it for a 5 speed or a 6 speed?
Old Sep 15, 2012 | 07:12 AM
GSX 911's Avatar
5 speed transmission
Old Sep 15, 2012 | 07:30 AM
Turbo01s2k's Avatar
Did you rotate it all around? Ther is only 1 combo that works persay, all others will leave 1-2 bolts offset.
Old Sep 15, 2012 | 12:29 PM
GSX 911's Avatar
One of the flywheel bolts was completely ripped out. All the thread is off the hole in the crank. I tried to re-thread it but just wont work. The crank is also warped, its not flat anymore.
Old Sep 15, 2012 | 10:53 PM
GSX 911's Avatar
bump
Old Sep 16, 2012 | 07:59 AM
ExViTermini's Avatar
The cranks are the same. They will interchange fine.
Old Sep 16, 2012 | 10:03 AM
GSX 911's Avatar
Thank you sir.
kaj
17
Jul 20, 2016 08:03 PM
AutoXMRIX
Mar 9, 2016 07:02 AM
jimifloydzep
Oct 10, 2014 07:41 AM
Diavlo
Aug 21, 2006 06:13 AM
Aby@MIL.SPEC
17
Feb 2, 2005 05:04 AM
