Evo 8 - 10.5 Hotside on an Evo 9 turbo?
Old Feb 23, 2011 | 12:40 PM
tim85851's Avatar
Question Evo 8 - 10.5 Hotside on an Evo 9 turbo?
Are the 10.5 hotsides interchangeable between the two turbos?
I have something to add to this question...do i need to run the Evo IX WGA with my Evo VIII 10.5 hotside or can i keep my Evo VIII WGA?
Old Feb 23, 2011 | 01:03 PM
ChrisCarey's Avatar
Indeed, compressor housings are not.
Old Feb 23, 2011 | 08:27 PM
tim85851's Avatar
thanks!
Old Apr 2, 2011 | 01:04 PM
tim85851's Avatar
Old Apr 2, 2011 | 01:18 PM
tim85851's Avatar
Bump!
Old Apr 2, 2011 | 01:24 PM
MaLo EvoVIII's Avatar
Thanx for asking this question. And thanx for the answer (MAPerformance). My evo 9 turbo has a cracked divider wall and all the 10.5 hotsides i find for sell (new or used) are for evos 4-8. I was scared of buying one of these and it not fitting with my compressor housing.
Old Apr 2, 2011 | 01:50 PM
sparky's Avatar
Are the 10.5 hotsides interchangeable between the two turbos?......
Yes, there are two 10.5cm turbine housing variants. One has a single puck wastegate flapper valve and the other one has a dual puck wastegate flapper valve. Both 10.5 variants are interchangeable between the IX and VIII turbos.
Old Apr 2, 2011 | 01:59 PM
sparky's Avatar
The turbine housing doesn't matter with respect to which actuator you need. Actually, the compressor housing dictates which actuator you need to use. A IX actuator is required with a IX comp housing whereas an VIII actuator mates up with an VIII comp housing. "Old Milwaukee"
Old Apr 2, 2011 | 02:01 PM
tim85851's Avatar
sounds good. thanks for that answer!
evo8john
Jun 9, 2010 10:36 PM
xmaciek82x
Midwest Region
Oct 17, 2009 09:07 AM
IXEvolutionIX
10
Sep 3, 2009 06:11 AM
tim85851
17
Jun 25, 2008 10:18 PM
EVIL_EVO_VIII
10
Feb 28, 2006 04:20 PM
