More compressor surge after WOT?
Old Nov 19, 2012 | 06:33 PM
asu11's Avatar
Whenever I do a pull in my car, it will compressor surge more than usual at low boost. Less than 5 psi. Anyone else have the issue? Should I be concerned? Running a Tial Q with 11psi spring on SD.
Old Nov 19, 2012 | 08:03 PM
blk2gdsm's Avatar
How do u have ur vacuum lines run? Do u have the bov T'd into the lines that have ur wastegate and boost controller hooked to it?
Old Nov 19, 2012 | 08:09 PM
asu11's Avatar
BOV vac line is dedicated all the way to IM.
Old Nov 20, 2012 | 01:07 PM
TiALSport's Avatar
is it 1/4" ID? is the source 1/4" ID?
what are you pulling for vacuum?
you're on SD...i'd throw a -6psi spring in the bov and call it a day
Old Nov 21, 2012 | 02:19 AM
asu11's Avatar
Yep correct size line. -22 for vacuum.
So I dont need the correct spring for SD?
90zcrex
Oct 10, 2012 06:43 PM
boonkae
Mar 2, 2012 06:12 PM
zakattack2011
Jul 12, 2011 08:23 AM
revhappy
Jun 13, 2011 07:30 PM
AlwaysinBoost
12
Nov 26, 2006 04:28 PM
