Pls Help - AFR Deeps til 10 whenever immediate Full Throttle!
Old Nov 21, 2012 | 05:33 PM
jameswwt's Avatar
Hi, my problem til today ever since i upgraded to S2 cams & ATP Gt3076R T3 4bolts turbo is whenever i immediate full throttle my AFR drops til max 10afr as shown on my AEM wb which makes my car hard to accelerate.
The only way for me to catapult is to go partial throttle and re-throttle again and again.
Ive since changed back to stock 560cc injectors with the stock latencies & scaling values.
Will it be my cams overlapping problem?
Is there a better way to set my S2 cams?
Im now using latest Synapse recirculate bov and minimal boost leak.
TPS on Full Throttle 96.5%
Boosting 1.45 bars base on WG pressure.
85.5mm pistons with 8.5.1 comp ratio
38mm Turbosmart WG
Other than that, car still runs massively aggressive on the lower end til top end but just cant immediate WOT.
Old Nov 21, 2012 | 05:52 PM
Gigs's Avatar
That seems like a lot of turbo to still be on stock injectors.
Old Nov 21, 2012 | 05:53 PM
idkmybffjjill's Avatar
Did you get a tune after you put in the S2's?
Old Nov 21, 2012 | 08:13 PM
jameswwt's Avatar
Yes, have been tune and have confirmed that my tune is ok.
The injectors still able to supply for the whp im having...
Reached 90% once awhile.
Is it due to the turbo lag or the sudden surge of air which my 2.0L cant consume fast enough?
(just a guess)
Old Nov 22, 2012 | 10:21 PM
jameswwt's Avatar
Anyone to share or advise?
Old Nov 22, 2012 | 10:27 PM
211Ratsbud's Avatar
A log would be an excellent start. What gears does this problem play in? First second third fourth fifth or seventh?
Old Nov 22, 2012 | 10:32 PM
jameswwt's Avatar
All gears 211...This is the mystery that i wish to solved all this while....
jameswwt
17
Jul 18, 2018 02:14 PM
EVO(boss)
Feb 16, 2015 02:34 PM
peewee996
Nov 11, 2013 01:11 AM
jameswwt
Feb 20, 2013 03:19 AM
jameswwt
Oct 19, 2012 11:21 PM
