FWD Conversion?
Old Nov 25, 2012 | 06:46 PM
SpeedTech_Cody's Avatar
FWD Conversion?
I'm looking to make a mid engine car from scratch and I'm planning on using an evo 4g63. Big problem with this obviously.... I need to convert the trans to fwd.
Does anyone know of any kit designed to do this or is it easily done by disconnecting the yoke, letting it free-spin and welding the center differential?
Old Nov 25, 2012 | 07:14 PM
211Ratsbud's Avatar
There's fwd transaxles that bolt to the 4g63.
Old Nov 25, 2012 | 07:22 PM
tony_b's Avatar
Be MUCH cheaper to get a 6 bolt 4G63 and a fwd tranny from a 1G...
Old Nov 25, 2012 | 07:30 PM
I'm going to be picking up the engine from a wrecked donor car, price won't be an issue. Plus I want the strength of the awd transmission. So I suppose there is no blockoff for the transfer case made by anyone is there?
Old Nov 26, 2012 | 06:48 AM
Craig King's Avatar
If you're building a mid-engine car, why are you going FWD?
Old Nov 26, 2012 | 08:36 AM
The engine and drivetrain will be over the rear wheels. Technically rear engined.
Old Nov 26, 2012 | 08:42 AM
itsmrrizz2you's Avatar
why not just use a 6 bolt 4g63. it will probably be cheaper for you?
Old Nov 26, 2012 | 08:43 AM
CurseDSM's Avatar
Yeah I agree I would use a 6 bolt fwd turbo motor and trans out of a dsm.
Old Nov 26, 2012 | 08:51 AM
All I want to know is if there is a kit to do this or not and if ill just have to weld the center diff and run without a driveshaft.
Old Nov 26, 2012 | 08:56 AM
llDemonll's Avatar
Ever consider the front wheels won't get any grip on acceleration?
There's a good reason you don't see any R-F cars in production
Old Nov 26, 2012 | 09:00 AM
SavageEvo8's Avatar
He is planning an R-R setup.. like an mr2, atom or lotus type design...
Old Nov 26, 2012 | 10:39 AM
Thank you, thought it was fairly clear due to the first post but apparently not.
Old Nov 26, 2012 | 11:02 AM
SavageEvo8's Avatar
some of us are pickin up what youre putting down perhaps labeling it as a transverse design woulda helped, then again that may have only confused folks even more. lol
wish i could help out. however the only swap/conversions i have ever built/owned was an AE86 i used to own.
Old Nov 26, 2012 | 11:51 AM
Boosted Tuning's Avatar
Like everyone else said, you best bet woule be to get a 4g63 outta a DSM with FWD.
Old Nov 26, 2012 | 12:03 PM
Raptord's Avatar
Then why does it say FWD in the OP and title?
