What oil do i need to fill the transfer case on my evo 9?
Old May 10, 2013 | 09:23 PM
intj123's Avatar
Diaqueen LSD is GL-5. Has an odd smell to it from some type of additive and the only gear oil I've smelt that smells like the Diaqueen is Motorex Prisma ZX.
Old May 10, 2013 | 09:49 PM
joseph143's Avatar
in all the years my car has been on the road its only had oem fluids with exception of the engine oil... however i do run oem oil filter...
after a long winded conversation with jack's transmission reps about fluids i was told you can run oem lsd oil, or shockproof in the tcase fill plug side of the tcase... however do not run it in the trans... either mt90 or oem fluid for the oem trans... if you have a wavetrac front diff motul is expectable.
that confusing tcase fill plug side of the tcase is because part of the tcase receives its oil from the transmission rather then what you poor into it... in fact it contains 3 different lubricants if you have acd
07chuck
Evo X How Tos / Installations
Aug 22, 2014 06:47 PM
EvoXcrzy08
Sep 13, 2010 07:06 AM
8UpUrV8
E85 / Ethanol
33
Aug 8, 2010 08:50 PM
shiroboi
Jan 14, 2006 08:20 AM
GVR-4
Aug 17, 2004 09:06 AM
