Unorthodox Hardpipe kit
I installed the Unorthodox Hardpipe kit today. It is a great pipe kit and the fit was perfect. It took like 3hrs. I have to thank Zach for hooking me up
. I took a few pics so here they are, ill take some more but i ran out of light.
Re: Unorthodox Hardpipe kit
Too bad the pics aren't working, anyway knowing Zack and having seen past pics the kit is definitely top notch. I was thinking of adding this to my car, mind posting about the before/after difference power wise, and what supporting mods you have with it.
I'm very interested in getting the UR hardpipe kit. But I notice that they are made out of mild steel instead of stainless or aluminum? Is that the case? Aren't they quit heavy compare to other companys pippings which use SS or Aluminum?
Well to me the difference in weight doesn’t bother me cause even if it weight 5lbs more what difference is it going to make. I hope that doesn’t steer you away from this kit, cause all the parts are top notch! The Pictures don’t do the kit justice cause the powder coating on the pipes looks incredible! And to be on honest may kits need some fabrication to fit. The only modification in this is just to cut the corner of the battery box that took a total of 10min! Best kit out there in my opinion!
