Intake questions
Old Dec 24, 2012 | 05:04 PM
RoryMarckese's Avatar
Intake questions
Got a new stm intake tube and ofcourse its not going to have hook ups to the vaccum lines. Jw where the one to the solinoid is gonna go after intake is in
Old Dec 24, 2012 | 06:27 PM
WikdEvo's Avatar
what intake did you guy? The only vacuum port that I know of on the intake is the on for the valve cover. When purchasing intakes, there are options to have the bpv recirc pipe or not.
Old Dec 24, 2012 | 06:33 PM
Its setup for recirc but the stock tube has 2 points for lines. One was run to the place u mensioned and the other is to the solinoid. I have the mbc run to the wastgate and turbo
heel2toe's Avatar
It connects to the valve cover. If there aren't provisions for the vacuum line, simply put a breather filter on the valve cover.
Old Dec 24, 2012 | 06:37 PM
WikdEvo's Avatar
Don't put a breather filter on your valve cover, that's just.... just don't do it. Post a link to the intake that you bought because right now we are just guessing.
Old Dec 24, 2012 | 06:58 PM
3K's Avatar
3K
If you're running an mbc, you don't need a vac line to run to the solenoid. Just loop a piece of vac hose to both fittings on the solenoid.
Old Dec 24, 2012 | 07:12 PM
Thank you the solenoid end was the one I was concerned with. Is it basically obsolete with the MBC installed. but for the breather line I was sent a little filter for the valve cover. here are pics as requested!
The bottom line (1) was the one hooked to the solinoid and the other (2) was to the valve cover. This came from STM and was supposed to bolt right up. I didn't recieve a tube to connect the BOV so I was going to reuse the clamp on the old one and cut some rubber tubing up from the hardware store to make it fit.
Thank you for the input guys. I am kinda a noob i know!
Attached Thumbnails Intake questions-2012-12-24_20-02-28_749.jpg   Intake questions-2012-12-24_20-01-50_683.jpg
Old Dec 24, 2012 | 07:18 PM
hiboost2.0's Avatar
Out of curiosity why do you say that? The breather nipple on the valve cover is for the crankcase ventilation.
Old Dec 25, 2012 | 12:17 AM
WikdEvo's Avatar
I prefer to go things the right way. Ie, catch can. How many high Ho shop builds do you see with a breather filter? Plus, some tracks won't pass you on the inspection with a breather filter.
Old Dec 25, 2012 | 09:11 AM
Im ok with the filter for now until i get a catch can.
Old Dec 25, 2012 | 12:41 PM
AreSTG's Avatar
one of the locals here had moisture freeze in the breather filter during winter. caused some issues. Probably a pretty freak thing to happen though. But, a catch can with no vacuum source would do the same thing...
Philly
Aug 22, 2013 05:25 AM
yeayeaatou
Jul 24, 2013 06:09 AM
M13x
Feb 28, 2013 03:43 PM
aby_george75
Lancer Engine Tech
Dec 19, 2012 08:27 AM
mac11wildcat
Nov 19, 2012 06:37 PM
