Cylinder 4 is 40 psi less than other. How long will my engine last
Old Dec 25, 2012 | 10:31 AM
riceball777's Avatar
I have a stock engine with about 120,000 miles. It has about 400whp and it been at that power level for most of its life.
Cylinders1-3 have 170 psi and cylinder 4 has only 135 psi. If I add oil in cylinder 4 compression will shoot up to about 165 psi. So I assume the rings are worn.
The car ideals and drives fine. How serious is this and how much longer can I drive the car? Is this a ticking time bomb?
Old Dec 25, 2012 | 11:21 AM
barneyb's Avatar
It is not impossible that one cylinder would wear more than the others but this causes me to think that the low cylinder is running lean. So, I would suggest looking at the fuel injector.
Old Dec 25, 2012 | 11:31 AM
wizzo 8's Avatar
Can you do a leak down test? If so see if you hear air escaping from exhaust, intake or crankcase. Is the car visibly burning oil from the tailpipe?
Old Dec 25, 2012 | 01:45 PM
The car does not burn oil or smoke. I did do a leak Down test and cylinder 1 is leaking a a out 10#. Cylinder 2 and 3 is leaking about 5%. Cylinder 4 is leaking about 35%!!! From what I can tell it seam like its warn piston rings.
Old Dec 25, 2012 | 01:49 PM
itsmrrizz2you's Avatar
Sounds like you coul use some fresh rings
The compression isn't the worst I've seen thow
Old Dec 25, 2012 | 03:29 PM
My question is how safe is it for me to push the car. Should I still be taking my car to autocross and such.
Old Dec 25, 2012 | 03:52 PM
WHTEVO's Avatar
If you want to get some more miles out of the car until a rebuild, i would try not to "beat" on it. But if you're just waiting for something to happen before pulling the trigger to do the rebuild, then just drive it how you would any other time. Sounds to me the rings are worn on that cylinder like others have said. Good luck.
Aaron
evoniners
15
Mar 10, 2014 01:02 PM
bambooi
Jul 14, 2013 12:52 AM
car_nut15
Dec 16, 2012 09:03 AM
Arxylis
11
Sep 25, 2012 05:08 PM
strikethree
AEM EMS
Apr 9, 2007 12:00 AM
