Manley 2.2
I agree with n2oiroc about the pistons, wiseco's are better. I've hear their forged cranks aren't bad depending on how far u plan on pushing the car but the billet cranks can take alot more abuse. Why are u going with the 2.2 instead of the 2.3? Are u trying to keep some rev's?
http://www.maperformance.com/manley-....2-94-150.html
this kit with 85/5 pistons , 94 billet crank and 150 rods. i want 2.2 because i want rotate motor 8000+ rpm. and good spool with 3076 gtx for example.
Some people in russia say that manley is bad kit. quality is bad .... so i need your advise
Oh, ok. Nah bro, Manley Turbo Tuff rods and billet cranks are up there with the best. The pistons are just not as good as wiseco's but buschur sells Manley pistons so they can't be that bad. I'm actually looking into getting Manley's 2.3 stroker kit. Manley's good quality.
I run a manley billet crank with turbo tuff rods... and use cp pistons. The reason for using CP is that manley did not have stock of pistons at the time. The turbo tuff rods is one of the best in the world, I am still to see one of those fail.
On the subarus the best performance piston I have found is the Manley with gapless rings...way better than wiseco....
It's not a bad kit. The best turbo's u could go with for fast spool would be the FPred or FPblack if u wanna stay with stock frames. The black will be laggier but will require less to make power. The red will spool faster but require more boost. If ur looking into T3's, the hta3076 or the hta3582's ur best bet.
