how to properly destroy your motor
Old Jan 3, 2013 | 02:17 PM
riceball777's Avatar
How much power was it making? What kind of turbo? Was there any damage to the turbo?
Old Jan 3, 2013 | 03:06 PM
sobo's Avatar
I would not have ran eagle anything in that motor, but that's just me.
Little looser on them clearances next time will do the trick.
Where you running an HLA regulator?
Old Jan 3, 2013 | 04:33 PM
TheBoz's Avatar
Man that is awesome. Thanks for posting pics.
Old Jan 3, 2013 | 05:12 PM
opie's Avatar
It made 741whp on a twin scroll 4088r. The turbo is fine I'm changing it to a twin scroll pte 6466. The 4088r was maxed out so I'm going to see what this 6466 is all about
Old Jan 3, 2013 | 07:54 PM
blknblubkrdude's Avatar
Are you running a MAF? I so, you might run rich with your crankcase vents not plumbed back into your intake.
Old Jan 3, 2013 | 08:39 PM
opie's Avatar
I'm on aem with sd
Old Jan 3, 2013 | 08:42 PM
I guess I didn't project my sarcasm well, haha. In any case, sorry to hear, hope the recovery goes well!
Old Jan 3, 2013 | 08:59 PM
mynx87's Avatar
Damn time to bring it back bigger and badder GL with the rebuild
Old Jan 3, 2013 | 09:18 PM
opie's Avatar
All the new parts are here for the new block.Im going with wiesco 1400hd pistons 10.5 comp with manley tt rods and going to keep it 2.0lt this time.
Old Jan 3, 2013 | 09:57 PM
GhostAWD's Avatar
Congrats your in 1st place for carnage of the year award! lol......
Was this the 1st time you ran the car at/close to that speed @ that boost pressure? Or was this the 1st time since the build the car was pushed this hard? If you pushed the car close to this hard on a regular basis loosely speaking it actually held up pretty well all things considered. Good luck with the rebuild tho
Old Jan 3, 2013 | 10:04 PM
opie's Avatar
it lasted about 2k miles of a hard life.
Old Jan 3, 2013 | 10:44 PM
BDecker9's Avatar
Damn, that's an expensive 2,000 miles
Staying with a 2.2 for the next build? And, wheres the video???
Old Jan 4, 2013 | 02:57 AM
TommiM's Avatar
Maybe Eagle Rods and Chinese metallurgy isn't all that bad then. Hell, If I can get 2000 pure track miles out of my build I would be happy. But then I consider myself to be a little harder on the car than most.
Old Jan 5, 2013 | 08:24 AM
KevinBoosted's Avatar
Spoken like a true boss! Where is this landing strip at and do you have any video of said 170mph carnage?
Old Jan 5, 2013 | 08:41 AM
Bean4G63's Avatar
Well i guess i pushed my built 2.2 lr a little to hard.it had an eagle crank and rods with je pistons.It looks like it spun a rod bearing causing oil pressure to drop then the rod let go bending the ams race balance shaft delete rod and locking up the oil pump.There is two holes in the block one in the front and one in the back.It blew at 170mph and 43psi of boost in 5th gear.
Looks like the oil pump went bad from lack of oil at the pick up, causing the spun bearing, which then heated up the rod and broke it.
