Arp 2000 hardware limit
Old Jan 10, 2013 | 06:07 AM
mrboost05's Avatar
So i am in the middle of rebuilding my motor a 10.5.1 2.3 i am looking to purchase rods i am leaning towards manley turbo tuffs but wondering if i should upgrade to the arp 625 rod bolts ?
Ive searched evom and googled the hell out of it so far ive found one post by map performance where they have said they have used the arp 2000 bolts in there 1053hp drag car and thats about it. i am thinking buschur uses them in his motors to but not 100% sure when should you upgrade ? i no rods bolts are rated by hp and rpms but is there even a need for the arp 625 bolts.
Old Jan 10, 2013 | 08:48 AM
n2oiroc's Avatar
the 3/8" arp 2000's are supposedly good for 200 hp per rod. the 625+ are 300+ hp per rod.
Old Jan 10, 2013 | 10:36 AM
mrboost05's Avatar
Thanks n2oiroc I ran across that info as well that would make it seem as if we are over using the bolts in a lot of our cars I am going to order them with my rods because its not much of a price diffrence for the piece of mind.
the Manly 300m rod uses the 3/8 Arp 2000 bolts and they say that rod is good for 1300hp and 1500hp with the 625+ bolts how is that the same bolt have different ratings in different rods from the same manufacture.
Old Jan 13, 2013 | 12:18 PM
mrboost05's Avatar
Bump for some info also looking at manley 300m rods now and pauter as well as the carrillo rods setup is 2.3 motor 10.5.1 weisco hd pistons hta86 turbo ect should never see over 8500rpms
Old Jan 14, 2013 | 08:38 AM
03whitegsr's Avatar
The 200HP vs. 300HP figure is off and is probably something somebody made up based on nothing at all but "gut" feeling. It would mean 625 is 50% stronger than ARP2000, which it is not.
625 has a yield strength of 260-280 ksi where ARP2000 has a yield strength of 220ksi. 625 is 17%-27% stronger depending on which figure you use. Use 15% though and if 3/8" ARP2000 can handle 325HP (1300HP/4 rods) then 625 can handle 1500HP.
But RPM and piston/rod weight is likely the limiting factor of a rod bolt anyway, not HP.
Old Jan 15, 2013 | 07:27 PM
mrboost05's Avatar
thanks that makes alot more sense.
bubba17
May 18, 2013 10:51 AM
RealStreet
Aug 24, 2012 10:31 AM
RealStreet
Aug 22, 2012 02:03 PM
TakaseEVOIXSE
203
Jun 3, 2012 01:30 AM
DeliriouS
18
Mar 13, 2010 05:51 AM
