GSR Rear Diff into MR
Will it be okay to do this? Are the final drive ratios different or something that causes a problem? The reason I want to do this is because I have a Cusco diff in mine that I want to swap in. It'll be the entire pumpkin
Thanks
Update:
Final drive ratio is stored in the trans!
Thanks
Update:
As far as I know its a direct swap with no difference in ratios. The only differences in driveline are ACD vs non-ACD center diff and different gear ratios in the 5 and 6 speed trans. The rear diff should be exactly the same.
Llew
20
Jan 23, 2021 02:40 PM
Llew
May 21, 2014 08:43 AM
Czarcasm
Aug 16, 2013 10:26 PM
discopotato03
Jan 10, 2011 12:52 PM
