How to crank engine
Old Jan 12, 2013 | 05:46 PM
silverevo05's Avatar
How to crank engine
How can I safely crank over the engine without it starting????
I want to build up oil pressure and oil the cylinder walls before trying to start it...
Can I just pull the coils out and let them hang out?
Thanks
Yes I have searched even on google but nothing specific
Old Jan 12, 2013 | 06:50 PM
evo7_8u's Avatar
just un-plug your coil plugs.
Old Jan 12, 2013 | 07:05 PM
loch's Avatar
unplug the crank angle sensor or pull the ecu fuse
Old Jan 12, 2013 | 08:10 PM
If i unplug the coils which i have already done anyway, fuel wont squirt?
And which is the ecu fuse, wont that make the oil not pump?
Thanks
Old Jan 13, 2013 | 10:04 AM
bump for info
Old Jan 13, 2013 | 11:14 AM
Svendiesel's Avatar
If you step on your gas pedal to WOT and crank the car with the crank position sensor unplugged, fuel will not spray and you'll build oil pressure.
One thing to be careful of though, which I did the first time, I believe if you step on your gas pedal for 3 seconds with the ignition in the on position, the car goes into valet mode and when its actually running, it wont rev past 3500 or 3000rpm when youre driving. I shat my pants when this happened the first time to me
Old Jan 13, 2013 | 10:49 PM
slvrslepr's Avatar
unplug the coils
Old Jan 14, 2013 | 09:24 AM
^ so I need to just unplug the two connectors going to the coils and turn the key??
For how long can this safeley be done??
Old Jan 14, 2013 | 08:22 PM
okevolutionVIII's Avatar
I wouldn't do it too long as the clutch puts tons of pressure on one of your thrust washers and doesn't allow oil to in between that and the crank. I would crank it 2-3 times then start it as it will get instant oil pressure, these aren't old technology engines that need cranking to build oil pressure.
Old Jan 14, 2013 | 08:35 PM
^ perfect thanks
fafaforza
Aug 4, 2014 10:09 AM
ralliart 04 21
May 17, 2014 05:23 AM
Coxor
14
Aug 24, 2013 11:02 AM
FinnMR
Jul 6, 2013 04:03 PM
jbuhrman
Jun 16, 2013 04:39 PM
