Any big gains with a 3.5" exhaust in 750+ HP?
Old Jan 13, 2013 | 06:37 PM
Jetfixrguy's Avatar
I am contemplating on building a 3.5" exhaust with my 6466 build. But curious if I should just keep the 3" Are the gains substantial? Meaning 50+HP and up? I plan on running 40+ pounds of boost in my 2.4LR 6466 E-85 combo. I will have about an 18" section of 3" coming off the turbo then into a 3.5 straight back.
Old Jan 13, 2013 | 06:44 PM
EvoDan2004's Avatar
depends if you have a ****ty flowing 3.0 exhaust or not. if you have a really crappy system now and you go to a very free flowing 3.5 then yes maybe you can see that type of gain. but if your running a free flowing 3.0inch exhaust and go to a 3.5 i highly dought you will gain much if anything. not under 750hp at least. pushing the car hard or looking to extract every ounce of power then i would opt for the 3.5 inch exhaust. 1/2hp is better then no 1/2 haha
Old Jan 13, 2013 | 06:50 PM
Jetfixrguy's Avatar
I have a straight open 3" exhaust into a magna flow muffler, I am pretty sure its free flowing. I plan on pushing the 6466 until I run out of fuel so who knows what it will make.
Old Jan 13, 2013 | 06:52 PM
EvoDan2004's Avatar
what fuel system do you have? it would not make sense for you to spend time and money building a 3.5inch exhaust if your fuel system is your limiting factor. no what i mean?
Old Jan 13, 2013 | 06:59 PM
Jetfixrguy's Avatar
double pumper/fic2150's/aem fuel rail,
Old Jan 13, 2013 | 07:03 PM
EvoDan2004's Avatar
i would say its your call then. you will not see 40/50hp gains though. maybe at the absolute most would be 10hp. even that is high. but if your looking for every ounce then i vote 3.5
Old Jan 14, 2013 | 10:10 AM
JohnBradley's Avatar
Yes.
I have 3.5", changed from an AeroTurbine to a offset in/centered out 3.5" Magnaflow and lost 50whp (794 to 739 at 39psi). Added a testpipe dump and got all the power back but the power diverged at 26psi which was 660whp in my car at the time.
Old Jan 14, 2013 | 03:48 PM
Jetfixrguy's Avatar
Originally Posted by JohnBradley
Yes.
Good info, thanks for sharing. The power difference does sound about right then.
Old Jan 14, 2013 | 04:06 PM
If I had losses like that on an existing 3.5" exhaust imagine the difference between 3 and 3.5" The next part of the equation that really makes a difference is the downpipe. Getting that as large as possible as quick as possible (preferably immediately) helps also.
Old Jan 14, 2013 | 04:16 PM
Jetfixrguy's Avatar
Very true! Well I am building my own top mount and am really running out of real estate for the wastegate and downpipe. I am confident it is all going to come together and would love to have a 3.5" coming off the turbo but still not 100% sure about the room for that. Hence my 18" of 3" into the 3.5" inch transition.
Old Jan 19, 2013 | 01:43 PM
shaz1980's Avatar
good info
Old Jan 19, 2013 | 03:45 PM
Drifto's Avatar
No comprendo...explaino??
Old Jan 19, 2013 | 05:17 PM
Both 3.5" mufflers flowed enough exhaust a 26psi that they made 660whp just the same on the 2.4/3586. Past that the power difference was more and more until at 38-39psi I was down 55whp from the aeroturbine to the magnaflow.
3.5" ETS exhaust with the 4" Aeroturbine vs 3.5" ETS with a Magnaflow 3.5" offset in/centered out. The Aeroturbine had a 3.5"-4" cone adapter and then the muffler (however long they are) vs the Magnaflow 12909 I think? I can look up what it is if need be. The Magnaflow dropped the drone/sharp tones at full power but also dropped power. I added a testpipe dump and got it all back though.
Old Jan 19, 2013 | 10:58 PM
irace2much's Avatar
I went from a 3" to a 4" exhaust and gained 150whp!
Not sayin to expect anything like that but it helped me out... We couldn't figure out why I wasn't makin the power I was expecting and then we looked in my none eBay but jdm 3" muffler and even though the inlet was 3" and the tip was 4" inside was only 2 1/2.
Old Jan 20, 2013 | 05:32 AM
Jetfixrguy's Avatar
Well going from 2 1/2" to 4" is a huge jump in reducing back pressure, so I guess I can see a big gain in power.
