Spark Plugs (Again)
Old Jan 23, 2013 | 03:12 PM
TeRoy EvoIX's Avatar
Spark Plugs (Again)
I've searched and read probably 15 different threads on this and am still not positive on what plugs I should run. Currently running an FP green, HKS 272/272, spoolin up cop, TBE w/ test pipe. 28psi spike and 24psi at redline. Going to change the plugs after I seafoam it. It runs great so should I just pull a plug and run the same plugs that prev. owner ran?
Thanks,
Anthony
Old Jan 23, 2013 | 03:19 PM
chamelieon's Avatar
NGK 5245 ILFR7H
Denso 5345 IKH22
thats it.
Old Jan 23, 2013 | 03:39 PM
ctfpevoVIII's Avatar
I like to run the ngk copper plugs, I change them about every 3000-5000 miles to keep optimal performance. You can run the br7es or bpr7es which is the stock heat range or go 1 step colder and run an 8.
Old Jan 23, 2013 | 03:52 PM
ILuvJDM's Avatar
we're going to assume that the OP has an Evo 9 because of his signature, make sure we specify which plugs are which for those who don't know better and search for this thread...
Old Jan 23, 2013 | 04:12 PM
My bad I didn't even look at what year his car was. To the op disregard what I said those are for evo 8's sorry.
Old Jan 23, 2013 | 07:25 PM
nightwalker's Avatar
I run AC Delco spark plugs
Old Jan 23, 2013 | 09:09 PM
Yeah I know the 8 plugs and 9 plugs are different. The 8's are shorter correct? I did read quite a bit about it but just wasn't sure if I should stick with stock or go a step colder. I ordered the ILFR7H. Thanks guys.
xXANCHORMONXx
May 9, 2013 11:13 PM
CtSilver03Evo
May 2, 2011 07:14 AM
IDRNKV8
Oct 31, 2008 08:26 PM
antwon6420
11
Aug 1, 2007 12:11 AM
