PROBLEM engine under load "choking"
Old Jan 23, 2013 | 10:09 PM
DagYo369's Avatar
Engine idles fine but when under-load it falls on its face with the slightest pedal pressure. When its idling its fine although when I rev it up slowly (in neutral) it acts like its trying to break-up for a second say around 4,500rpm. I've tried swapping out plugs and coils and same result. Heard it could be boost leak but took a quick look at couplers and all seems tight. Is there any sorta of sensor that can randomly take a **** or happened o rattle loose? Also i've thought about getting soapy water and running it around couples to cheap for bubbles but i just dont think its that. And the cam gears line up with marks on valve cover never got around to taking lower timing belt cover off. Any help would be appreciated! Thanks in advance. Motor is stock with a works flash. And this problem just randomly came about no warning signs.
Old Jan 23, 2013 | 10:24 PM
BEKevo's Avatar
Did you gap the spark plugs? .026
Old Jan 24, 2013 | 02:38 PM
DagYo369's Avatar
Ya the original plugs and current plugs were all gaped correctly. Going to take ic piping off this weekend to look at all couplers but also up for anymore ideas!
Old Jan 24, 2013 | 07:09 PM
Craig King's Avatar
Try turning your boost controller down and see if it still does it.
Old Jan 27, 2013 | 09:10 AM
DagYo369's Avatar
Whelp it was the most common thing, fml! Although I ran through and checked tightness on clamps for the piping when I pressurized the system I found the leak. Doh!
rpople
Sep 19, 2013 09:22 PM
DagYo369
Jul 31, 2013 01:29 PM
jsmits2689
22
Apr 11, 2012 06:15 PM
MitsuJDM
11
Sep 4, 2011 04:36 PM
ct9a gsr
38
Mar 28, 2006 08:50 PM
