Evo VIII stuttering under load
Old Sep 15, 2013 | 03:04 PM
rpople's Avatar
Hi everyone - relatively new member but long-time Evo owner...
I have a bone-stock Evo VIII with 115k miles on it. I've owned it since new, and all the miles are mine.
My problem: under a full throttle, it stutters at around 4,000rpm and again at about 6,000. Normal driving seems fine, though after 30 minutes of driving the idle will be a little rough.
It has had all its scheduled maintenance; I've replaced plugs, plug wires, cleaned the K&N filter and replaced the PCV check valve within the last 200 miles (the problem became noticeable about 500 - 1,000 miles ago).
Any help or thoughts would be greatly appreciated!!
Thanks!!
Rich
Old Sep 15, 2013 | 03:19 PM
twabtoxer's Avatar
What kind of plugs are you using? What gap on the plugs?
Regap the plugs to .20 try that
Old Sep 15, 2013 | 05:33 PM
sktng22's Avatar
is it stuttering when it hits a certain boost?
Old Sep 19, 2013 | 09:22 PM
Airflow86's Avatar
I had the same problem a lil while ago. Fresh set of .22 gaped plugs cleared it right up. Also boost leak test it.
Evolcomk
16
May 30, 2015 11:33 AM
roydollabill
Jul 19, 2013 12:54 PM
NY Evo
Mar 13, 2013 05:20 PM
10isace
Nov 14, 2012 10:13 AM
SethWillits
Apr 14, 2009 09:59 AM
