I blew my engine,, please help
Old Jan 24, 2013 | 08:37 AM
luislm21's Avatar
i blew my evo 7 engine, and i dont know why
i need help with my issue, because i need to find the reasons
and i want to know what to do to rebuild the engine
1) I have stock engine, stock turbo and i use stock boost(18psi)
Old Jan 24, 2013 | 08:51 AM
BogusSVO's Avatar
How did the engine blow?
Rod knock?, rod break and come thu the side of the block?
Crank walk?
Blown HG?
Blowing smoke all the time?
Timing belt break?
Melt a hole in the piston?
What clutch is installed?
How many miles on the engine?
Pics of the damage?
Old Jan 24, 2013 | 09:05 AM
luislm21's Avatar
melt and hole in the piston #1
Old Jan 24, 2013 | 09:07 AM
luislm21's Avatar
ill take pics tomorrow, the spark plug ground electrode got broken
Old Jan 24, 2013 | 09:15 AM
fastyouth1313's Avatar
melted a hole in piston 1?
Old Jan 24, 2013 | 09:19 AM
luislm21's Avatar
yes,,, piston #1 a hole and scratched the cylinder
definatly got to hot in that cylinder. check the injector in that cylinder. sounds like the fuel injector took dump and that cylinder leaned out and got super hot!
Old Jan 24, 2013 | 09:30 AM
luislm21's Avatar
the spark plug groud electrode got broken
Old Jan 24, 2013 | 09:37 AM
BogusSVO's Avatar
The hole in the piston, and the busted spark plug are both from a lean condition in the cylinder.
Have the fuel injector tested.
Old Jan 24, 2013 | 09:47 AM
luislm21's Avatar
how it can be tested?>???
Old Jan 24, 2013 | 09:59 AM
powerdriver's Avatar
Shoot me a message, I know someone who will test it for decently cheap.
Old Jan 24, 2013 | 10:06 AM
BogusSVO's Avatar
Some NAPA parts stores have a Fuel injector test center, so call around, or send them off to one of the Fuel injector suppliers.
But from the sounds of it, you will need a new set of pistons, and have the block bored, depending on wear, and how deep the scratch in the cylinder is.
The head may have to be gone thu also, due to the melted aluminum that has spattered on the valves, and seats.
Old Jan 24, 2013 | 10:41 AM
luislm21's Avatar
afortunately the head is in perfect condition, i live in Dominican Republic i dont know where to test my injectors.
Old Jan 24, 2013 | 10:45 AM
itsmrrizz2you's Avatar
get your injectors flow tested you went lean
Old Jan 24, 2013 | 10:47 AM
it depends what company they are you can send them back to them and they will flow test them. i know ID, bosch, and fic flow test injectors
