Major PSI leak, need input
Old Jan 30, 2013 | 10:25 PM
Seamus7's Avatar
Lightbulb Major PSI leak, need input
I'm noticing a def lag in psi when spooling up, maybe 8psi but haven't tested it yet for a leak, that this weekends project. But have noticed while spooling on the stock 04 plastic BOV, when it blows off we all know you get the "pshh" sound, but during spool I'm hearing a "ssshhhhhhhhh" sound from the BOV like its dumping while trying to build boost, is this common? Crappy Evo 8 BOVs?
Old Jan 30, 2013 | 10:49 PM
BEKevo's Avatar
Take the BOV off and test it on a bench with a pump or do a boost leak test. Either method will let you know if you're BOV/DV is leaking. It's generally a good idea to get the Evo 9/ JDM BOV sooner than later, it'll save you headaches down the road.
Old Jan 30, 2013 | 10:51 PM
Seamus7's Avatar
Thanx man
Old Jan 30, 2013 | 10:59 PM
sktng22's Avatar
the stock evo 8 diverter is pretty bad.
Old Jan 31, 2013 | 04:58 AM
EvolutionRR's Avatar
check the BOV that is the main problem.
Old Jan 31, 2013 | 08:41 AM
MLucas13's Avatar
boost leak test
Old Jan 31, 2013 | 08:51 AM
MLucas13's Avatar
and probably common sense but check all intercooler pipes and couplers and make sure ur intercooler itself isnt leaking
Old Jan 31, 2013 | 09:08 AM
funyun's Avatar
I had that same type of sound and just tested mine, turns out one of the clamps was cutting into the Upper IC pipe hose and had a real bad leak. Another thing I noticed when I had 25psi going into the car with my synapse DV hooked up to the UICP I could put my hand over the side on the DV that goes into the intake and after like 30 seconds it would blow off and let all the air out does that mean it has a small leak?
Old Jan 31, 2013 | 10:14 AM
jfogg's Avatar
Maybe throttle body seals? I had a major leak there in the past. Goodluck with the fix
Old Jan 31, 2013 | 04:07 PM
evotuner04's Avatar
15 Year MemberLikedLoved
boost leak test, ditch the plastic 8 diverter asap. dont be surprised if its throttle body seals. and take a few minutes to look under the car that intercooler couplers make sure theyre tight. doesnt take much to blow off if they arent tight and positioned right
vaflyboi757
21
Aug 10, 2015 10:40 PM
vr4gasmtt
Jun 14, 2015 10:12 PM
zakario
Nov 9, 2013 12:06 PM
EvoPooPoo
25
Jun 26, 2011 12:30 AM
Don Q
10
Dec 23, 2010 05:16 PM
