Need some advice and help on which way to go.
Ok guys, I've been researching the past few days and we all know its tax time, well I think I've finally made up my mind I'm going FP green. I will be getting tuned on 93oct being as e85 is not in my area. Just had a couple questions, as far as injector size and a fuel pump what would you guys recommend for a 400-450whp setup. Only current mods are a 3 in turbo back and the AMS frontmount. The second question is the guy who had the car before me made 609awhp. Of course he took most of that off before being sold, but it has the AEM centermount gauges and he says they will not work without the AEM EMS system, is there any other way get these to work, or will i have to buy new gauges with my new setup I am purchasing? Also as this car will probably be driven 3-5 times a week would a cam install while I am it be a good idea?
I knew I would get that answer, I have been searching, and wanted exact answers for the setup I planned. I don't know about you, but I don't wanna purchase things that don't fit the setup. I understand a lot of Evo's run the green setup, but my case is also daily driving etc... and the question about the gauges I can't find anywhere.
I will call you possibly monday to let you know one way or the other, Also need to contact the previous owner to see if he has already installed the walbro. I was thinking the S1 cams though, do the HKS work with the stock valve springs?
Yeah, but the s2's require valve springs, and also are for 500-700 whp setups, and according the store are not suggested for smaller or stock appearing setups, as stated I only want 400-450 whp range and keep the drivability for daily driving.
s2 / s3 / kelford 272 all good cams for the green regardless what the cams say on the site.
FIC 1100cc high-z injectors will be more then enough fuel, and will perform real smooth on 93octane with more then enough fuel delivery.
for fuel pump a single walbro 255 hp modified will be more then enough fuel.
if you need help / assistance on parts feel free to pm me and ill help you out.
For your power goals I'd go with S2's. I'm running them with a BBK-B and don't have any issues with daily drivability. The extra cost from the springs would be worth it IMO
Alright, thanks s2's it is, that or if I can get those HKS 272's from the member above for cheaper I will do so.
