sparkplug wires/boot
Old Feb 3, 2013 | 04:33 PM
EvoIXPilot's Avatar
I was changing my sparkplugs today and one of my boot separated from the "thing". Is this now unusable and I have to get a new one. Or can just put it back together and reuse?
Attached Thumbnails sparkplug wires/boot-sparkplugs.jpg
Old Feb 3, 2013 | 05:05 PM
oscarquinones's Avatar
spark plug wires
i recommend to change it is not to work properly i check ebay sold the two OEM coils brand new $ 48 with free shipping
Old Feb 3, 2013 | 05:07 PM
spark plug wires
put evolution ix coils and search
Old Feb 3, 2013 | 07:22 PM
EvoIXPilot's Avatar
I'm being told the the coil boot sometimes come off the coils pack and just reinsert, making sure the spring inside the boot is attached??
Old Feb 3, 2013 | 07:48 PM
hiboost2.0's Avatar
Put it back together, start the car. If it works the car will run fine if not you'll hear a misfire at idle. It will be pretty noticeable if it misses at all.
Old Feb 4, 2013 | 12:00 AM
adriano_917's Avatar
You do know they sell the wires and boots separately right ? If you dont know what you're doing take it to a technician that knows please!!!
Old Feb 4, 2013 | 09:37 AM
dastallion951's Avatar
Personally depending on miles, id replace the coil boots, and new wires, if one has cracked the others arent too far behind....cracked coil boots can cause arcing in the head which can cause multiple issues starting with misfires. Thats my 0.02 , as far as new wires at the time, before going to sparktech cop, I swapped plug wires to Magnecor 8.5 mm wires...which worked well.
Old Feb 4, 2013 | 11:55 AM
EvoIXPilot's Avatar
Nope, I don't know, but I have to learn sometime. I was following along the DIY guide. After searching/Google that I found out the boot is a separate piece from the coil pack. So, basically, I can just put boot back on the coil pack.
gregivq
Lancer Engine Tech
43
Dec 2, 2018 09:23 AM
John Ralleca
26
Nov 13, 2017 08:41 PM
jmb_silvester
Nov 29, 2016 09:31 PM
omniprobe
Aug 26, 2010 08:02 AM
4no
Lancer Engine Tech
11
Jul 22, 2009 05:14 PM
