tb boost leak....help needed
Did a boost leak test and found massive leak from the place circuled in the picture. Can someone help me out at how to fix it and explain what this part is doin?
Ok. Where can I find this O-ring? From what I've read in the last hour, it's an unconventional size and hard to obtain at regular. Has anyone else bought just this o-ring, and if so, where?
i had a similar leak there and also added high temp silicone sealant to help. The oring is not impossible to find, i believe i got mine from a generic assortment from a local autoparts store
I found a set of o-rings that Home Depot sells that works. Held 25psi in a boost leak test perfectly fine:
http://www.homedepot.com/p/DANCO-40-...6754/100579460 (the real ones do not look like the donut that the image depicts)
I'm not sure how long it'll last since it's made for faucets, but I have yet to find the right size anywhere else.
VRSF Tiago
EvoX 'For Sale' External Engine / Power
173
Jul 29, 2019 08:55 PM
VRSF Tiago
83
Dec 14, 2011 08:06 AM
