Speedometer reading slow
Old Feb 15, 2013 | 10:29 AM
SQ2Evo's Avatar
I just finished up my clutch install and everything seems to be working great except for the speedometer. I noticed that it's reading about 5-8 mph too slow and I confirmed this with a GPS speedo. I never had this issue before so I assume I just over looked something.
I did notice that there was a coating of grey "stuff" on the sensor when I pulled it. It looked like anti-seize compound. I didn't remove it cause I figured it was some sort of factory application.
Anyone have any ideas on what could be causing the incorrect reading?
Old Feb 15, 2013 | 12:08 PM
Kracka's Avatar
Do you have factory size tires?
Old Feb 15, 2013 | 12:26 PM
MechTech's Avatar
+1 If your not running factory wheels/tires that can cause this. It is possible the sensor is on its way out but I would looks elseware first.
Old Feb 15, 2013 | 05:51 PM
SQ2Evo's Avatar
Yes and the speedo read right before I did the job. Somethings gotta be screwy with the sensor. Anyone know what that stuff on it from the factory is?
Old Feb 15, 2013 | 06:33 PM
sktng22's Avatar
that is probably dielectric grease or anti seize
qu evox
16
Feb 9, 2009 07:22 PM
Christoforo
Dec 26, 2008 07:18 PM
858SD
Jan 28, 2006 07:17 AM
sthiewes
Aug 30, 2004 12:08 PM
Voi_airwolf
Apr 10, 2004 05:28 AM
