Evo 8 clutch slave cylinder!! ASAP
Clutch slave cylinders are nothing special... check local auto parts stores rather than going with a factory over priced unit. I believe I got mine from Oreilly's Auto Parts and it was like 30 bucks maybe. Its been on the car for over 10k miles with zero issues. These simple parts are just that, simple. No need to give an arm and a leg for a simple cylinder.
Valid point. All I can say is that my new one looks exactly the same, inside and out, as the old...the stock one I took apart to see what the hell happened and noticed that because of a small hole in the rubber boot, rust was in the end of the cylinder. That caused the seal to start leaking...bought the new one, took it apart to see just what was in there (worst case I'm out 30 bucks) aaannnddd it looks the exact same. Seems to work the same too
BUT mine is an Evo 8...so if for whatever reason they (slave cyl) are different, my experience/info is useless lol. Cheers
FS[SouthEast]: Clutch Slave Cylinder BNIB *Cheap***
Yoga_EVO
Jan 27, 2015 07:23 AM
freshevo8
May 24, 2009 11:21 AM
