Injectors high/low impedence
Old Feb 17, 2013 | 07:57 PM
Czarcasm's Avatar
I did alot of research on my e85 setup thats in the making. I want to go with minimum 1000cc injectors but Im stumped when it comes to low/high impedence. I know high imp. is 12volt and low imp. is 5volt (give or take). Im not sure if our evos have a resistor box or if they have direct 12v injectors.
So questions are:
If we have a resistor box (I think its the rectangular shaped relay on the firewall) do I remove it?
If we dont have a resistor box, do I just drop in the injectors and wire up the connectors?
Or are you guys saying this guy shouldve stayed in the honda scene
Anyone that can chime in on this would be helpfull
Old Feb 17, 2013 | 08:16 PM
STLEVOIX's Avatar
Evo's do have the resistor box. You can buy a resistor bypass from several different vendors...check Spoolinup I know they carry them.
Old Feb 17, 2013 | 08:33 PM
Czarcasm's Avatar
Thank you sir! So i was right about the box being on the firewall and i found the resistor pack bypass. Reading diagrams is not a bad idea
Old Feb 17, 2013 | 08:37 PM
sktng22's Avatar
maperformance also carries them
bbyevo8u
15
Nov 2, 2016 06:04 PM
maperformance
Oct 10, 2013 07:25 AM
JustAfewPosts
May 23, 2013 03:29 PM
maperformance
53
Oct 4, 2012 07:34 AM
porsherules911
Nov 4, 2011 10:51 AM
