2 last sets MAP 2000cc High Impedence Fuel Injectors w/ PnP Adapters (Evo & DSM)
MAP 2000cc High Impedence Fuel Injectors (Mitsubishi Evo X)
I ONLY have two sets of these in stock...that is it...once they are gone, there will be no more! PM me for details!
MAP 2000cc fuel injectors utilize the same modified Bosch fuel injector as many of the other guys, but at a more affordable price point. These bad boys include plug and play adapters so installation couldn’t be easier, however, being that our Evo 8 / 9 are high impedance injectors you will need to remove your resistor pack which will entail some wiring unless you pick up the resistor pack delete plug available below! Please note these are not to be used with oxygenated fuels like Q16!
Optional FIC Resistor Pack Delete Plug
To avoid cutting and splicing your DSM or Evo 8/9 resistor box harness, simply remove the resistor box and plug in the FIC Resistor Box Delete Plug. Easy! For use when replacing OEM or aftermarket low impedance injectors with high impedance injectors. ($22.00 additional)
