Need HELP deciding on CLUTCH!! 700+hp
Old Feb 17, 2013 | 04:31 PM
2ndLaw's Avatar
Exclamation Need HELP deciding on CLUTCH!! 700+hp
Hey guys, I need some good quality info on what clutch to run. All opinions are of course welcome, but I'm hoping to find some ppl with first hand experience. I've researched quite a bit on the different clutches ppl are using and I'm having a hard time finding good solid answers. I'm looking to make over 700hp with my 2.3 stroker and need to find a clutch that can hold. This car never sees the track (any track) ...this car is my toy that I only take out on the streets. That being said, I probably wont ever launch this car, as there would be no point, and I will mostly be driving normally with the occasional race. I do drive aggressively, as I'm sure most Evo owners do, but nothing too serious. Going from my last setup, I still have my ACT 6 puck clutch and it has less than 2k miles on it...but unfortunately, I'm not sure it'll be able to handle the torque. However, I don't really want to spend 1500+ on a new freakin' clutch...especially since I just put the tranny back in without thinking about the clutch ... SOOO, I need to know what everyone is experiencing with their clutches. If I have to spend the money so be it, but I want something that will last and not go through clutch disks like water. As of right now I'm leaning towards Quartermaster 8-leg Race... Thoughts? aaannnddd GO!
Old Feb 17, 2013 | 04:37 PM
Riddle's Avatar
I have a exedy triple disk clutch and I can't complain about it.
Old Feb 17, 2013 | 04:41 PM
2ndLaw's Avatar
I read this thread earlier... Given that you have the same clutch, do you have any opinion on it?
https://www.evolutionm.net/forums/ev...en-before.html
Old Feb 17, 2013 | 04:43 PM
Riddle's Avatar
I seen that but I don't have that problem. I know multiple people personally running the clutch with no issues as well with very hard driving. I also think STM runs it. I think its a very good clutch.
Old Feb 17, 2013 | 04:44 PM
boosted91t's Avatar
That thread is the exact reason I have yet to purchase or recommend the exedy triple. If they sort out the hub isses which should be as easy as machining it out of titanium or a very hard treated steel I am in to buy one.
Old Feb 17, 2013 | 04:45 PM
Riddle's Avatar
Guess I'll find out when it happens :-P
Old Feb 17, 2013 | 04:51 PM
RussellDaniel's Avatar
I wrote up a similar thread like this about a month back. Clutches are a scary decision but I finally decided on the quartermaster 8 leg. It can handle 900 tq.
Old Feb 17, 2013 | 05:12 PM
2ndLaw's Avatar
How many miles have you put on the car, how are you liking it so far?
Old Feb 17, 2013 | 05:16 PM
GGevo921's Avatar
I run a Tilton twin carbon as my car makes 830whp on a mustang dyno and is a drag car only. However I have driven many different clutches on high power evos as well as have quite a few friends with high hp Evos that had to make the same decision as you. Your going to end up spending money on the clutch as your power levels will demand it when you actually use your car. My suggestion is the quartermaster hydraulic 8 leg. Very smooth engagement, holds power well, shifts great and is a push conversion making you never have to worry about The retainer clip popping out. My good friend Joey runs that in junkbox and has gone 8s on that clutch and makes 800whp. I have driven a few quartermaster and I have nothing but good things to say. Just my opinion, but for the price as quality I think it would be your best choice.
Old Feb 17, 2013 | 05:39 PM
2ndLaw's Avatar
Very helpful, thanks! The most annoying thing is that I have to take that freakin' tranny out again...just put it in yesterday. Its bad when spending 1500 bucks is less stressful than pulling a tranny lol. At the moment I am leaning towards Quartermaster because it seems to be able to hold just as much, if not more power than the Exedy. I have heard that they are quite noisy, but I guess thats not really a deal breaker considering its not exactly quiet now. Thanks again
Old Feb 17, 2013 | 06:41 PM
n2oiroc's Avatar
there are different versions of the quartermaster. if the car i street driven more than occasionally, get the street version. its easier to drive, but still shifts great.
Old Feb 17, 2013 | 07:47 PM
2ndLaw's Avatar
I'd probably rather go with the race version because it can hold more torque and they're the same price. Might as well go big or go home. I'm still not dead set on the quartermaster just yet, but with all the stuff I'm reading about the Exedy triple is making me think that the QM is the more practical clutch...
Old Feb 17, 2013 | 07:54 PM
1QYK9's Avatar
First off, the power in which a clutch can hold is rated in torque and not horsepower.
Given your very limited budget for a clutch and your power goals, the QM 8 leg is your only choice. An Exedy triple, which probably won't hold any more power than the QM (and you have to worry about the clip popping off) is almost $1000 more.
QM all the way.
Old Feb 17, 2013 | 08:41 PM
2ndLaw's Avatar
QM all the way.
Yes I know that its rated in torque. The only reason I mention the power is because I'm not exactly sure how much torque it'll make. (Also the reason I mentioned it was a 2.3) However, my 700+ hp goal is temp, I'm sure. Believe it or not, I thought 550 would be enough. ... I'm just never satisfied lol. This is also the reason I'm looking for the best bang for the buck and it looks like QM is the best option so far. I am trying to find more on how long they last under relatively normal driving conditions. If I knew that the Exedy would outlast the QM by a dramatic amount, the money wouldn't be the issue...but I'm not a huge fan of throwing money away on something thats exactly the same as something else thats half the cost. I assume you have a QM clutch? If so, what has been your experience thus far? Thanks for your help
Old Feb 17, 2013 | 09:06 PM
RSGuy's Avatar
You'll probably be around 550 ft/lbs give or take. You should be find with the Quartermaster.
