EVO 8 Transmission Rebuild 5MT questions.??
Hey guys, ever since i bought my car i've had a 5th gear issue. I was debating whether to buy a used one or just have mine rebuilt. I think i'm going to end up rebuilding my trans, by a reputable shop. Just trying to see what are the common things i should purchase when rebuilding the 5MT.
Also looking to maybe upgrade the gearing in it, final drive..? Maybe a differential while we're at it. Any good aftermarket upgrades??? I'd greatly appreciate the help.
only a couple options for the Center Differential in that w5m51 Trans, thats a Quaife and it isnt part number QDH13B as listed its a QDH11B. Its acutaly hard to find now i tried lol.Not to many people upgrade there center diffs thou, the front diff inside the Tcase is the one you wanna do first. Upgrading the Final drive to a 4.00 or 4.11 is a option but that also depends on what you wanna get from your car. The Ultimate trans gear ratios, that many rebuilders offer IMO is better then just a final drive. It takes the best Ratios from a 8,9 Gear box and combines them. the final Drive gear and shaft will change all Gears. Again it depends on what your needs are, I.E dont wanna hit 5th in a 1/4 mile? better MPG? or wanna be quicker? Or maybe Cruise the Highway at a lower RPM. I just rebuilt mine, i went all stock Evo 9 stuff but with a Quaife QDH11B, why? cause my Center diff was shot, it was run low on oil from a blown Tcase seal. Otherwise i woulda just stayed stock CDiff.
Evonrails
10
Feb 22, 2010 07:15 AM
Solo II Evo
Apr 22, 2009 03:08 PM
