4g63 on AEM series 2 and Bent cyl 4 ex valve??
Old Feb 25, 2013 | 09:29 AM
kartectuning's Avatar
Solved!
Old Feb 25, 2013 | 09:53 AM
sobo's Avatar
Originally Posted by kartectuning
Guys
I am running a stock evo 9 engine with the following mods
Kelford 272 mivec cams
Stock long block (stock head and valves, stock valve springs and retainers)
Rev limiter set at 8200 rpms
Gates timing belt
Stock balance shafts in place with belt
ARP rob bolts
Running a gtx 35 at 30 psis with an aquamist hsf3 and a twin nozzle setup on stock ecu for 2000 miles
Change to Aem series 2, ran 50 miles and one or two exhaust valves at cyl 4 got bent
Cylinder compression on all cylinders at 120 psis even, conservative tune.
I can understand the softer stock spring may have give in and causing valve float touching the piston, but in the subaru world with avcs valves tend to drop when the AEM series 1 variable valve system approach (cam sensor signal input basicly) was not well engineering causing erratic fluctuactions from sensor reading,
I would really like to hear of bent valves situations caused only by running stock springs that may tend to float, or rocker arm issues, I really do not want to hear that anyone had a similar issues running the aem series 2 even on stiffer springs, because that will really sad with a built engine...
Let me know if you have had a bent valve issue from valve float, on wich ecu please
Have you ever been inside an evo 9 cylinder head?
Can guarantee you floated a valve into the piston. Kelford 272 are very aggressive cams with 11mm of lift. They are NOT designed for stock springs and retainers, and definitely are not designed for a higher rev limit than stock when using that particular spring set.
There is no tuning involved with the exhaust side cam on an evo 9 motor, only the intake. So unless you aligned the timing belt wrong, you had valve float.
Old Feb 25, 2013 | 09:56 AM
reactionevo8's Avatar
It seems unlikely that the aem would cause an exhaust valve to bend since it has zero control of the exhaust cam timing..
Old Feb 25, 2013 | 09:57 AM
Drifting Away's Avatar
Old Feb 25, 2013 | 12:04 PM
Yeap the Mivec only controls the intake cam phasing against piston/crank position, all the findings point to exh valve float and no issues with Mivec AEM, its was just a coincidence to get the problem after a couple of hundred miles after AEM was put
I am tearing apart head now, will post some pics for future newbies to know how important springs are when changing camshafts
cheers
EVO 4 life
Nov 15, 2016 07:11 PM
Speedlimit
Apr 24, 2014 06:04 PM
nestoledo
Lancer Tranny/Drivetrain Tech
Nov 18, 2011 11:08 AM
PHILLY EVO
Mar 7, 2009 08:43 AM
SRT4 to Evox
Feb 25, 2008 05:48 AM
