Exedy Triple Plate Clutch vs Quartermaster Twin disc
Old Mar 9, 2013 | 05:00 PM
Lexus01IS's Avatar
I had 8 Leg QM clutch. It was noisy as hell. I will be installing Exedy Triple in next few months. I bought Triple HR for 2.4LR build.
Old Mar 9, 2013 | 05:21 PM
car_nut15's Avatar
Well that sucks...
Old Mar 9, 2013 | 07:51 PM
batty200's Avatar
One other nice thing about a pull clutch is that when the clutch is in it actually pills the engine and transmission together vs trying to push them apart. It helps prevent loose bolts from breaking clutch plates and bell housing
Old Mar 10, 2013 | 08:10 AM
SrBlacksheep's Avatar
Originally Posted by car_nut15
I'm in the same boat. Rebuild my exedy triple or try the qm 8 leg street. I know people said in the past that the qm's were noisy, harsh and did not last long. Has that changed now? Can someone with an 8 leg chime in??
What was your experience with the exedy tripple?
Old Mar 10, 2013 | 09:17 AM
SmurfZilla's Avatar
My QM was good to me before my car died but I'll be re-using the same clutch in my next Evo. The 8leg wasn't quick to need to be rebuilt I thought?
Old Mar 10, 2013 | 09:29 AM
car_nut15's Avatar
I bought my car with the triple in it. I got the car cheap because the clutch needed a rebuild so I couldn't really tell you what its like. I'm debating whether to rebuild the triple or try something else...
Old Mar 11, 2013 | 02:47 PM
car_nut15's Avatar
Bump. There's gotta be some more guys that can chime in on the Qm 8 leg
Old Jul 12, 2013 | 10:32 PM
95lsvtec's Avatar
From what i heard about the QM clutches is that their old design didnt have a solid hub for discs to sit on. Now that they have this new design i believe they are doing alot better. I am in the same boat whether to do a QM twin or exedy triple. By time im ready for the clutch the car should be dynoing around 900whp so its a lil more above avg. for your standard evo
Old Jul 13, 2013 | 06:33 AM
SmurfZilla's Avatar
Originally Posted by Dynotech Tuning
Also, push clutches do apply pressure against the thrust bearings on dry, cold startups which can cause a bit more premature wear compared to the pull type clutches, which actually remove the forward load on the thrust bearings during startup. This is one reason the DSM's used to disable the clutch switch so they could start the engine without the need to depress the clutch and apply pressure to the thrust bearings.
-Jamie
Clutch bypass is your friend
Old Jul 13, 2013 | 06:35 AM
SmurfZilla's Avatar
Originally Posted by batty200
I wouldn't recommend the QM clutch for a true daily driver. The 7.25" clutch doesn't like Stop and go traffic or hills. I had to change my disks in my PTT every 12k miles. That was every 6 months for me. I am putting it back in possibly since my car won't be a daily driver any more.
You are talking about the 8leg?
I have over that on my car and its been ok thus far.
Old Jul 27, 2013 | 03:20 PM
Hi all,
had a lot without going through this post I made, I have to tell, that in the end decided I bought the 8 LEG QUARTER MASTER TWIN DISC RACE 5-Speed ​​Hydraulic TOB (Street version), I have to say that is an excellent clutch a little noisy but when its performance is very good. Unfortunately it only used 430 miles, because I decided to sell the car because i purchase another evo with lot of performance like new and it have a Carbonetic Tripple Carbon like new. So i dont will use the QM clutch.
Even I have the clutch almost sale here in the forum. It cost me around USD $ 1,850 dollars and sell it for only USD $ 1.300. The clutch still need 70 miles to complete the break-in.
This is the sale link if someone is interested:
https://www.evolutionm.net/forums/sa...onditions.html
Also im selling a Power Fc djetro and HKS camshaft here:
https://www.evolutionm.net/forums/sa...-camshaft.html
Old Jul 27, 2013 | 04:38 PM
xRoguex's Avatar
exedy twin is the hands down best street clutch for mild to moderate builds...
clutches handle tq.. not hp. What tq will you be making? 2.0? Takes a lot to get 450+tq from a 2.0.. but 500whp is certainly possible.
Old Jul 27, 2013 | 05:09 PM
prockish_03evo's Avatar
I agree with xRoguex... Run exedy twin. It will handle 550hp very well and last a good amount 35-50k depending how you drive and is less noisy than my Quartermaster 8-leg. I loved my exedy twin but can't shift has fast or hold the power a Quartermaster will and the tripple is just too dang heavy imo.
Old Jul 27, 2013 | 06:14 PM
car_nut15's Avatar
I've been running my QM twin 8 leg for a few thousand miles now and can say this clutch is a lot more harsh/noisy than the exedy triple. For a street driven car it is a little much. That being said it is a dream to launch and seems to be holding up really well so far.
Old Jul 27, 2013 | 07:18 PM
xRoguex's Avatar
i have recorded .24 second shifts with my twin....?
