Emergency HELP on Drivetrain problem !!!!!
Old Mar 19, 2013 | 02:27 PM
SilverShadow03's Avatar
Originally Posted by Sourav mahmud
12 days ago when I changed my water pump..
You might be slapping the valves on your pistons like someone else mentioned....not sure though but it sounds more timing related than anything.
Do Not Drive The Car like this (purely my recommendation, obviously).
You need to do a leak down test and determine if your valves are bent or not. Do a compression test too while you are at it.
If you fail the leak down test, then you will need to do a head job with new valves (replace bent ones or all exhaust or all intake or all of both depending on how many bent valves are) gasket kit, etc... I had to do this last year..not fun and cost me a pretty penny.
Report back to us with your results/findings.
Old Mar 25, 2013 | 12:15 PM
Any updates?
Old Mar 27, 2013 | 01:53 AM
Sourav mahmud's Avatar
Originally Posted by SilverShadow03
Any updates?
Hey SilverShadow. Thanks for you first comment which really helped me to find out my problem . It was related to Timing. I found the problem after i opened the OIL Sump and saw the balance Cam was to adjusted properly. Now the car runs smooth like butter. Thanks Everyone for helping me out. At first I thought My Gearbox was dying .
Old Apr 1, 2013 | 01:00 PM
Awesome! Good to know you worked it out.
Fireescape
Jul 4, 2016 11:18 PM
eddy5201314
Apr 3, 2014 03:25 AM
Sourav mahmud
Dec 30, 2012 09:13 AM
2literturbos
Feb 5, 2010 08:27 AM
Alacris
Aug 17, 2005 05:38 AM
