Fuel
Old Feb 15, 2004 | 05:52 PM
SSKILLA's Avatar
Fuel
I just a aem intake and a 3inch full turbo back ......now i went 1% higher on my safc2 and im getting fuel cut at 21psi......a buddy of mine says it did it cause it may be too rich.......with these mods will i need to go richer or higher......and no i cant get her dyno tuned yet, the cash flow is a little slow....would i need a new fuel pump as well???
Old Feb 15, 2004 | 05:53 PM
SSKILLA's Avatar
sorry typo.......Richer or Leaner
Old Feb 15, 2004 | 06:05 PM
JeffWels's Avatar
what grade of fuel are you using? fuel cut is usually due to detonation.
Old Feb 15, 2004 | 06:47 PM
992gnt's Avatar
This is wrong. Fuel cut is caused by the ECU seeing more air than it thinks it should see. Maximum airflow is preset by the programming in the ECU from the factory. If the MAS sees (counts) more air than this preset level, you will experience fuel cut. Likewise, if you add fuel to an already richly tuned car, you will increase the pulsewidth of the injectors. Once that get to the max threshhold (the ecu thinks the injectors are compensating for more air) you will reach fuel cut.
There are two ways to relieve fuel cut. Bigger injectors which will have a lower pulsewidth than a smaller injector for the same output and 'fooling' the ECU into thinking less air is coming into the motor. This is what all piggyback fuel controllers do - intercept the MAS signal and raise (richen) or lower (lean) the signal before sending it to the ECU. SSKILLA, your car is too rich. If you're not sure what state of tune your car is in, you really need to be cautious making adjustments.
Old Feb 16, 2004 | 03:47 AM
JeffWels's Avatar
I stand corrected I was under the impression that fuel cut was due to the computer detecting so much knock that it pulled too much timing. then couldn't compensate so it cuts fuel as the end all solution to the detonation problem. Thanks for the clarification
Old Feb 16, 2004 | 08:13 PM
SSKILLA's Avatar
thanks for the info ....you know what your right i set it all back to 0% amd shes runs fine......i guess i have to save some cash to get her tuned.......whats the best a/f ratio to use thats safe
Old Feb 17, 2004 | 12:29 PM
berkel's Avatar
Just to share,
I had never dealt with fuel cut like this coming from an NA Honda (GSR) and a lightly modded A4 1.8T. When I heard "raising the fuel cut" I though people were raising the revlimiter .
Furthermore, I thought that fuel cut meant I needed to richen it on the SAFC, but it's actually the reverse. With the cold weather here in the Northeast, settings that were fine in warmer temps can start causing fuel cut, since the air is much denser, so you have to adjust it from time to time. Actually, I think you're better off lowering the boost if you can, rather than leaning it too far to compensate.
Take care,
FB
