APEXI AVC-R:Where to get replacement boost check unit?
Hello all
Who can supply a replacement for the damaged part of my APEXI AVC-R?
The small unit that measures intake boost is gone through corrosion
Here in Switzerland they tell me its not possible to get a replacement
Thanks for any help
ric
. Here in Switzerland they tell me its not possible to get a replacement
Thanks for any help
ric
If I recall, the part is not all that uncommon, its possible you can buy this part directly from the manufacturer (of the sensor) but I am not certain who makes it, its probably marked on the unit.
Although your not in the USA, you might want to e-mail or call ApexI (USA) and ask about the replacement part, I do recall seeing in the ApexI instructions that they had part numbers for a replacement solenoid and pressure sensor.
