Quick question about GSC R2 cams and valve springs.
I'm pretty much dead set on buying a set of R2 cams. I have a set of Manley springs and titanium retainers installed, will these springs get the job done with a 12.1mm lift?
usually manufacturers have a spec sheet with their cams/springs and the spring specs should tell you the seat pressure and allowable max cam lift with their springs before coil bind. so either call up manley or check their website.
im used to supertech springs in everything since they list clearly all that data.
Is there somewhere on a springs spec sheet that can give me an answer? It shows that the max lift is. 0580" on my Manley singles which is in the 14mm range but at this point, if I have to swap springs, it's a no go.
until mr. retainer played with mr. cutter
Sorry for hi-jacking the thread did not want to spawn a fresh one
What about S2 cams and Manley springs/rets? Part number MANLEY 26125?
Will they work? Cannot find any referenced data so asking about known setup.
just wondering I am currently running the PAC Beehive valve springs in my evo 9. Am I able to run GSC r2 cams with these valve springs?
here are the specs:
Specifications
Part# PAC-1523
Description Nitrided version of PAC-1223.
Weight (grams) 45
LargeEndI.D. (inches) 0.742
LargeEndO.D. (inches) 1.105
InstallLoad (LB) 85
InstallHeight (inches) 1.500
OpenLoad (LB) 263
OpenHeight (inches) 0.950
CoilBindMax (inches) 0.880
LiftMax (inches) 0.550
FrequencyBase (CPM) 38138
here are the specs:
Specifications
Part# PAC-1523
Weight (grams) 45
InstallLoad (LB) 85
OpenLoad (LB) 263
Think so, it says max lift is .550 inch and max lift of the cam is 12.10mm on the intake side which converts to .48". You should check the retainer to seal clearance once installed before you fire it up. Looks like you are ok with coil bind as well.
mrg7243
Jun 16, 2015 10:55 PM
tscompusa
Vendor Classifieds
Jul 19, 2013 04:14 PM
riceball777
15
Jun 18, 2012 11:02 AM
evoWWrs
GSC Motorsports - Charleston, SC
Mar 5, 2009 05:08 AM
