Installed mbc, boost wont go over 12psi
Like the title says, i installed a hallman pro rx mbc. Ive triple checked the lines and they are correct. Still using light spring. No boost leaks. Lines are ran as follows: side port to waste gate and end port to port on mani.
The 12# that you saw is probably the actuator spring pressure, right?. You may want to increase spring pressure by adjusting the actuator rod to a shorter overall length so that the turbo will spool better.
galantman03
43
Feb 5, 2017 09:54 PM
mitsubeastlee
15
Oct 30, 2014 05:54 PM
