New motor, lean idle (18.0)
Old Apr 17, 2013 | 04:35 PM
Toxin's Avatar
So we got a car in that came with a blown motor and overall the car is in terrible condition. Everything just seems to be destroyed or blown that I put in my hands...
The car has a new built engine now - just regular forged stuff, 2.0, 9:1 CR.. China intercooler 3", HKS 280 cams (the old ones) and a random K&N small cone filter - on the stock rubber tube and MAF location. Evo metal dump valve. Fuel system is still stock by the looks of it - we didn't check the fuel pump if it's stock or not tho, injectors are however...
Running the stock map - it's lean at low rpm and idle. Idles at 18ish AFR and stutters. Touching the gas raises rpm and reduces the condition but still nowhere near the 14.7. At ~1300 rpm the afr is at 16 or so... However when going out for a cruise and driving slowly the cruise afr bounces from 14.4-15.0 so that seems normal.
The car does not have the rear o2 sensor at all - just chopped wires hanging there.
I haven't pushed the car yet so can't comment on anything wot related, the new motor has 5 miles on it or so now.
Things checked:
- no boost leaks
- no exhaust leaks
- front o2 sensor replaced with a working one
I can't log fuel trims - just 0's on all trims. Injector latency, scaling etc is stock.
Anyone has an idea what could the reason for the lean running be? What can I do to log fuel trims without the rear o2?
Cheers in advance!
Old Apr 18, 2013 | 05:43 AM
Toxin's Avatar
Anyone?
Old Apr 18, 2013 | 06:38 AM
mt057's Avatar
An exhaust leak maybe? Are you running a rear 02 simulator, since it is not hooked up?
Old Apr 18, 2013 | 06:54 AM
cfdfireman1's Avatar
I guess a good question is why can't you log fuel trim? Don't fuel trims come from the front O2 sensor? Your working front sensor may be working but if that work's not reaching the ECU you have a problem. Broken wire maybe?
Old Apr 18, 2013 | 07:25 AM
evo8426's Avatar
If the ECU was not flashed to allow for the rear o2 to be deleted then he will not get fuel trims.
Old Apr 18, 2013 | 09:08 AM
Toxin's Avatar
I flashed it with tephra mod and deleted the rear o2. Same thing.
Old Apr 18, 2013 | 10:47 AM
boosted91t's Avatar
He should still have a STFT, or front o2 sensor voltage.
Old Apr 18, 2013 | 05:49 PM
Originally Posted by Toxin
I managed to fix the o2 and I'm getting fuel trims logged etc. They're within 5% all the time.
I bumped up the idle to 1000rpm and it's idling around 15,7ish afr now and low rpm cruise around 15,2.. I'll have to play with the MAF a bit I guess now.
I was guessing it could be the cams overlap causing this?
What did you find with the O2 sensor sir?
Old Apr 19, 2013 | 12:59 AM
Toxin's Avatar
Replaced the front one, simulated the rear one with tephra mod.
Old Apr 19, 2013 | 07:45 AM
evo8426's Avatar
I have seen people do this mod but incorrectly and still would not get readings. Care you post up the actual tune for the car so were all not blind?
turbotaloon95
29
Jul 12, 2016 07:42 AM
turbotaloon95
Jul 11, 2016 06:54 AM
Green_Bandit
Lancer Engine Management / Tuning Forums
Jun 19, 2013 04:39 PM
Toxin
Apr 18, 2013 03:20 PM
nj1266
125
Jan 12, 2010 07:37 AM
