6 speed transmission issue ( bearings ) + Pic ??
It looks like I found a bearing that will work with minor changes.
MRC 306SZZG
the bearing is 0.5mm thicker, so the two small plates that lock It in need to be shaved down a bit, and a thinner spacer needs to be ordered.
the trans I was working on came with a 0.82mm spacer, and the smallest spacer I can order from the dealer was 0.44mm part number MN168077.
I have opened up 3 of these 6-speed transmissions, and every output shaft bearing made noise.
MRC 306SZZG
FS[SouthEast]: Precision 6262 T3 .82ar 4bolt - 750
MacMan
Nov 14, 2015 01:48 PM
stunt2
Jun 8, 2014 08:27 PM
MacMan
Oct 3, 2013 10:40 AM
