Longevity
Old Feb 18, 2004 | 11:15 AM
Peteman100's Avatar
Longevity
I'm new to the Evolution so I apologize if my question is stupid. I've read that the turbo spools to a maximum of 19 psi in stock form. Considering the WRX has 13.5 psi and the STi has like 15, 19 psi seems like an aweful lot for such a small engine. Does anyone have any concerns about the longevity of the engine pushing that much boost? I really like the Evo but this is my only apprehension.
Peter
Old Feb 18, 2004 | 11:17 AM
YellowFever's Avatar
19 is not even enough for that turbo... i've seen people turn up the boost to 22 psi
Old Feb 18, 2004 | 11:20 AM
Ookami's Avatar
The WRX & STi are Aluminum-Alloy Blocks, the Evolution is a Cast Iron Block.
Old Feb 18, 2004 | 11:21 AM
nebolic's Avatar
i think you're sort of mistaken, as i recall, your boost spikes at 19 psi and drops down to 16psi, so no you're not boosting at 19psi, you're actually boosting at 16psi. that what you're holding.
Old Feb 18, 2004 | 11:22 AM
dpardo's Avatar
I am not an expert but, from what I have read, the engine is more than capable of withstanding that boost pressure. In fact, as previously mentioned, people are raising the boost pressure and also upgrading to larger turbo systems while retaining stock internals. The engine in the EVO has been around for some time and many tuners are capable of safely extracting quite a bit more power (over stock) from it.
Old Feb 18, 2004 | 11:28 AM
mifesto's Avatar
adding to what ookami mentioned... aluminum alloy block is lighter but far weaker... cast iron block are bulletproof
Old Feb 18, 2004 | 12:13 PM
Speedlimit's Avatar
Admin Emeritus
If you are considering just the block, the 4G63 is very impressive and as mifesto stated pretty much bullet proof. Many DSMer's with built motors routinely run with boost in the low to mid 30 psi. You can always tell the high boosters at the track; the dipstick has been either pinched or a setscrew drilled in to keep it from blowing out of the block.
To answer you question, daily driving with peak boost at 19 or 20 psi should not change the life expectancy of your car. How you drive will make the difference.
Speedlimit...
Old Feb 18, 2004 | 12:21 PM
bluevilevo8's Avatar
19 psi is nothing for this motor. If you maintain in properly, it will last a long, long time.
Old Feb 18, 2004 | 02:12 PM
Peteman100's Avatar
Thanks
Thanks guys. That absolutely answers my question. Damn the evo rocks!
Old Feb 18, 2004 | 02:16 PM
SilverEvo8owner's Avatar
I know of some people running 22 PSI to redline with a boost controller and turbo timer being their only mods. Is it healthy? I'm not sure, but I've been told 21 PSI is relatively safe.
Old Feb 18, 2004 | 02:20 PM
evo542's Avatar
Boost-Solutions.com put on 42psi on the stock block, and when they took the engine apart, no signs of detonation, everything looked clean
https://www.evolutionm.net/forums/sh...threadid=65483
Old Feb 18, 2004 | 02:25 PM
evo542's Avatar
on 91 octane 20psi, is the most you should use
Old Feb 18, 2004 | 05:14 PM
jcnel_evo8's Avatar
reading...
In general if a turbocharger or supercharger is used to extract more horsepower out of a motor...a general rule of thumb is 2x horsepower (from N/A) = ~20% more engine stress...on the rods at least. So boosting a motor (if built well in the first place) will not introduce too much more stress on the internals themselves.
Other factors become more important, such as overall oil flow, tranny strength, detnoation (a really big issue) and temperature.
Yes...High boost has its 'issues' but in this day and age the technology has come far enough along to boost a motor, for some high-torque fun!
Later,
jcnel.
Old Feb 18, 2004 | 05:32 PM
dsm95hybrid's Avatar
It's all relative to air fuel mixtures and egt's. I would be more concerned about the turbo's capacity before anything. Then head studs & head gasket. If you have enough fuel, intercooler or WI to keep things cool you could boost 30+ daily.... 4g63's have taken a s-load of boost over the last decade.
Old Feb 18, 2004 | 05:38 PM
Charlie-GT's Avatar
how much psi where the past evos runnin on??/
(evo 1-6)
sik_z33
Jun 20, 2016 08:08 AM
EVO8LTW
Sep 7, 2010 03:44 PM
bennmandee5203
29
Apr 30, 2010 01:00 AM
dubbleugly01
11
Mar 20, 2006 03:46 AM
