What is pinout for stock boost solenoid?
Old Apr 30, 2013 | 12:40 AM
wang4u's Avatar
I see the ecu diagrams, but do not know what wire goes where on the solenoid itself. Any insight would be great
Old May 7, 2013 | 10:06 PM
jrainwater's Avatar
Boost solenoids dont have a + or - side. They're interchangable. So don't worry about which wire goes where.
Old May 7, 2013 | 10:25 PM
Dynotech Tuning's Avatar
+1
-Jamie
Old May 8, 2013 | 12:07 AM
wang4u's Avatar
With that said, would I be correct to say, one side goes to the ecu, one side goes to 12v constant? Assuming the ecu output is a ground output.
Edit: I forgot to mention, the factory bcs wiring is not available. The original builder didnt want to use an ebcs so the harness was taped up. To take advantage of a Grimmspeed bcs, Ill need to run the wiring.
Old May 8, 2013 | 08:21 AM
I will need to check the diagrams but I would assume one goes to the MPI relay and the other to the ECU.
-Jamie
Old May 8, 2013 | 09:19 AM
wang4u's Avatar
-Jamie
You maybe correct. I see one end of the bcs going to fuse #2, main engine fuse. And the other to pin 11. I found this good diagram for a Hondata solenoid, so Im confident any switched 12v source on one end, pin 11 on the other.
Ima give it a try this weekend. Otherwise, have a mbc ready to be installed too.
Its funny Hondas use the same pin 11 wire..
Freddy302
Oct 14, 2016 05:04 PM
[TK]
For Sale - Part Outs
Aug 4, 2016 11:37 AM
domyz
Aug 3, 2016 10:48 AM
Babs
AEM EMS
Jun 28, 2014 06:48 AM
SkyNight
Jun 15, 2011 05:33 PM
