hi guys
Old May 2, 2013 | 02:15 PM
lancer evo9's Avatar
Post hi guys
what is the maximum PSI for engine position oem evo 9 ?
Old May 2, 2013 | 02:17 PM
i dont know
Old May 2, 2013 | 02:21 PM
SilverShadow03's Avatar
Are you talking compression testing your engine or what the stock boost is from the factory?
Not understanding your question.
Old May 2, 2013 | 02:38 PM
yes i am talking about compression testing for maximum psi
and sorry for my question.
Old May 2, 2013 | 02:43 PM
i mean , if i change the turbo oem to bigger and cams, what is the maximum pai for engine position ?
psi
Old May 2, 2013 | 02:45 PM
Ev0ikon's Avatar
That's an odd question, but I'll bite. I think the most I have seen is just under 200 PSI. The number isn't that important. What you want to know the the difference between the numbers from each separate cyl.
Old May 2, 2013 | 02:46 PM
160s PSI range...which should be your baseline numbers.
Here is something I read in another EvoM thread..
"Low compression in one cylinder usually indicates a bad exhaust valve. Low compression in two adjacent cylinders typically means you have a bad head gasket. Low compression in all cylinders would tell you the rings and cylinders are worn and the engine needs to be overhauled."
Your poor English makes it difficult to answer your question. Sorry....
EVOLution9LOVE
Feb 27, 2014 10:34 PM
bryonboals
Feb 25, 2014 10:01 PM
vipevo9
Aug 26, 2013 07:34 AM
vipevo9
evoson23
May 31, 2013 11:09 PM
